has been home a couple of days now, and I got to get a little "man time" out on the cruiser this morning.What do you mean "out of phase"???Don't forget to install it with the u-joints out of phase. It sounds odd, but that's the way the front drive shaft on an 80 is supposed to be.
OK, I don't know what happened to it, but I had another post up here showing a chunk missing out of the drive shaft on the other end. I went ahead and replaced all of the bolts. and since I had to use a 6" extension and impact swivel socket to get to them, I added some torque. I think I bumped it up to like 60 FtLbs. IM'ed CDan and found out that a new drive shaft is required, somewhat over $350 with his discount. So, I found a junk yard that happens to have a '97 and it still has the front shaft. A buck and a quarter...that's way more doable. So I took off my front driveshaft this morning, and locked my center diff. Smooth sailing all the way up to 80 MPH.
Pinhead is "da man". Looks like a new used driveshaft is in order. Saturday I go out to the lot and see what else might be salvagable off of the truck.
The missing chunk is actually on one of the ears on the rear portion of the front drive shaft. Not on the companion flange, but the shaft itself.Where's the missing chunk?
I'm always glad when something I screw up helps someone else!!! I don't think you'll need a straight edge even. Those are pretty beefy splines, I believe that you'll be able to tell which one will put you 90 degrees "out of phase"...OMG, you got to be kidding me. First off, thanks for the pictures of your drive shaft and the junk yard drive shaft. I always knew the front drive shaft was supposed to be out of phase, but never really knew what that meant. Your description and symptoms of vibration and noise where similar to a problem I was having. I called it the woo woo blues, but in my case it wasn't a roar and it occured at a little slower speed.
I just went out to the garage, its 5 degrees out, got on the frozen concrete with a flashlight, and my front drive shaft is in phase. I marked it and replaced the front u joints last spring, so it wasn't me. Must have been the reputable truck shop in town that I paid 1300 to replace the broken axle/birf and throw 2 new front rotors on. They also screwed up the inner axle seal(no spring), causing birf soup, and destroyed the c clip inside the new birf when putting them together. Three strikes on one simple job, EGGIMAN MOTORS in MADISON WI will never touch my cruiser again. I did the front end rebuild a few months after having them put the new axle/birf in, because it had never been done and I had birf soup because of their crappy job.
So I'll take the front DS out, put it outa phase, should I get it balanced or can I just straight edge eyeball it outa phase? I guess I might as well replace the u joints while its out, since they're probably toast from being in phase? I bet this will solve my woo woo blues.
Lesson learned, again, someone please hit my thumb with a hammer.
my original shaft is neither in phase or out of phase, but actually in between!!!! .
