Front control arms
Kamiah ID
So I was crawling around under my rig the other day.. seems like I spend a bit of time under it these days.... and noticed that my front control arms have a bend in them, as in bowed in twards the transmission about 6-8 inches from the frame mount.
Is this normal or did the PO mess them up?
Yeah.. they are both bent inward twards the transmission by about 1/4 to 3/8ths... looks like Im in the market for some new control arms..
Now I'm wondering what caused that. Someone else will probably chime in if it's happened to them before.
Are you running caster plates, or drop brackets, or anything odd that you think could have bent both of them in like that?
Should be able to find some used ones easy enough.
As for the cause, could be a number of things but likely just from running hard. I know @woody has bent a couple sets on his 80. It happens.
Im sure on of the PO's bent them rock crawling, there is much evidence under my rig of rock rash and even the frame is dented in one spot.
This rig went through hell before I got it, now it has a cushy trail/back roads explore and camp rig job!
Last time I took mine off, I straightened them in a press....and I keep one avail as a spare now....
If you have a press, it is perfectly ok to straighten them out. The arms are forged and you wont likely cause any damage.
Work case you make it worse and have to buy new arms as you already planned. Check with cruiseryard for parts.
Just one? I have a pair if you'd like.
They're a little too heavy to go with the bump stops, though.
You keep a pair on hand or you have a pair you want to sell?
Shipping them would be rather cost prohibitive. I have a pair of them from when I went to the Superior Engineering arms.
I'm in Phoenix, if you can figure something out for getting them here, shoot me a PM
