front caliper upgrade
Groveland MA
Website
landtankproducts.com
This might seem timely to the recent brake upgrade thread but it has been in the back of my mind for a while and I needed to baseline the truck first before moving forward with it.
So recently I replaced all the calipers and the master cylinder with Napa rebuilds. Not to much of a hassle but I did have a hard time bleeding the front calipers after the master cylinder was replaced do to the cold. The cold thickened the brake fluid to the consistency of vegetable oil and it didn't flow into the cylinder very well after a bleed. But with higher temps today all is well.
So basically I've mapped out a change where a larger 4 piston caliper could be used on our trucks. It's still a 4 piston unit but the pistons are around 5mm larger in diameter.
So the question is, what can I expect for gains and issues if I were to do this?
I'm at the point were I need to purchase some hardware to further investigate the possibility so it still might be a bust but I wanted some idea on the worth of doing this.
generally, with the same master cyl you look for multi piston calipers with the same cap of fluid vs movement, but more pistons apply the pressure over a bigger area more efficiently.
slotted rotors and batter pads would be give you better performance than just slightly larger pistons.
A larger dia rotor would also help, if you could move the caliper further out.
That sounds like a great idea. As to whether or not it will be a big improvement, I'm not sure. Common sense would make me guess that larger pistons = greater force applied. Also, I'm guessing they hold a larger brake pad, which would have to increase performance as well. If anyone can make it work, I'm sure it's you.
On a side note, are you happy with the Napa rebuilds? What did the calipers and MC cost? I'm thinking of getting new calipers myself, and wanted to see what other options there are vs. OEM.
How big in diameter are the current pistons? I'm thinking on the order of 40mm IIRC. If so, another 5mm in diameter would be about a 20% increase in the surface area, which should equal about that much more force on the pads as well. I expect you'll have more pedal travel to realize that though.
also the ratio of front vs rear volumes needs to be looked at.
There is a rear caliper you could use with larger piston area as well.
while the backing plate for the pad is larger to accommodate the larger piston area the pad surface area is about the same. The donor vehicle is another Toyota with basically the same rear calipers as ours. Dan would be quick to point out that the part numbers for the rear calipers are different but the newer style has eliminated that tin piece that bolts with two screws to the top of ours.
The Napa rebuilds were OK. One of the rear calipers was one without the bolt holes for the tin plate and one of the front calipers had a retaining ring for a piston boot loose in the box. Their re-mans were Aisin units at about half the price of Toyota re-mans. Time will tell if the savings were worth it.
Based on what I've experienced I would think that this would be beneficial. On 60/62s you can swap in stock 4runner calipers or aftermarket SSBC calipers. Both are still 4 piston but the pistons are larger than the stock 60/62 pistons. I'm running the SSBCs which are 4x45mm and the difference is very noticeable. The SSBCs take stock 60/62 pads so it's the increased size of the pistons that is making the difference. Those that are running the 4runner calipers also have reported excellent results.
I've done some more research and it seems that this is a real popular upgrade on gen III 4Runners and Tacomas. I'm not really thrilled with how they went about changing over the brake line but that is easily over come. These calipers have a short hard line with a standard JIS flare that goes from the caliper to an anchored hose connection while the stock units use a banjo style connection.
So you're going to go through with it? I sure hope so and best of luck. Keep us posted.
The wife's truck gets torn down again tomorrow for more measurements and comparison. That usually means removing a caliper but she's a good sport about it.
I've got an e-mail into a re-cycler (junk yard) for the needed parts off of a 2006.
I'll keep everyone posted.
I asked about this a while ago and was shot down (because of how I asked and my ignorance) - I'm curious to hear how this works out but I think we'd benefit more from a larger rotor (energy capacity) and moving the caliper out.
As far as increasing the caliper piston sizes, the 93-95 non-ABS T100 has a 1 1/16" master cylinder that will bolt in place of the 80 MC to offset this. (drop pedal travel but require more force for the same stopping power, I doubt you want to do that but just throwing it out there)
The newer rotors that are mated to these calipers are only .5" larger in diameter and 4mm thinner. But some how this small change and the larger calipers corrected warping problems and improved braking.
Right now the biggest issue is that our rotors are 4mm thicker and the new calipers physically won't slide on.
So what donor are you working with?
2003+ 4Runner w/17" tires, S13WGs. The calipers should be here any day. Part of the mod will require that the calipers be widened by 4mm. Traditionally the two halves of the calipers use a single O-Ring for sealing and I'll need to have some shims machined to accept two O-Rings, one on each side, that will get bolted in to provide that 4mm spacing. Then custom stainless steel brake lines and it's done.
At least that's the plan.
Are you going to try to get some quantitative before & after data? Do you consider the current brakes on this truck to be good (for an 80)?
Thanks!
Thanks!
no quantitative data, just seat of the pants. With my lifted truck I think the brakes are ok but could be better. After driving my wifes 4Runner there is no comparison. Also the Tundra had warping and braking issues and these calipers are similar to their re-design.
Because of the rotor mounting system on our trucks there is no easy way to swap over a larger rotor from a different application.
I am liking this idea, sure glad you're putting in all the research into this.
On your custom ss line, will it replace the short rubber line that is currently going from caliper to axle fitting or are you thinking of a ss line that connects to the existing rubber line? Sound like it could work out to get upgraded calipers and new ss lines at the same time.
Wow, LT, got into this a little late but terrific thing to do! I've got a suggestion and I hope that this does not spin off into the incredibly tired drilled and slotted vs. solid argument but DBA makes a model of rotor they call the "5000 series" which has removable hats which could conceivably mean you could swap the hat to an 80 series rotor with a larger rotor as allowed by whatever wheel yer runnin. I have not taken the time to get the actual part numbers for this swaparoo but ...
Disc Brakes Australia - DBA PRODUCTS
Good luck, as always, we love it when you pioneer another awesome upgrade! :cheers:
Edit: Crap linky no worky, just go to DBA and lookup the Series 5000 rotors, sorry, dunno why it isn't working.
2nd Edit: Well crap again, now the link looks like it is working, go figure, anyways hope this helps (HTH).
