front caliper upgrade
I am liking this idea, sure glad you're putting in all the research into this.
On your custom ss line, will it replace the short rubber line that is currently going from caliper to axle fitting or are you thinking of a ss line that connects to the existing rubber line? Sound like it could work out to get upgraded calipers and new ss lines at the same time.
I'm hoping to replace the rubber hose that goes from the frame to the caliper with a Stainless steel one. I have found a vendor on line that makes custom lines but until I actually get the caliper mounted I won't know the length.
Wow, LT, got into this a little late but terrific thing to do! I've got a suggestion and I hope that this does not spin off into the incredibly tired drilled and slotted vs. solid argument but DBA makes a model of rotor they call the "5000 series" which has removable hats which could conceivably mean you could swap the hat to an 80 series rotor with a larger rotor as allowed by whatever wheel yer runnin. I have not taken the time to get the actual part numbers for this swaparoo but ...
Disc Brakes Australia - DBA PRODUCTS
Good luck, as always, we love it when you pioneer another awesome upgrade! :cheers:
Edit: Crap linky no worky, just go to DBA and lookup the Series 5000 rotors, sorry, dunno why it isn't working.
2nd Edit: Well crap again, now the link looks like it is working, go figure, anyways hope this helps (HTH).
I sent them off an e-mail. The ability to swap out the rotors might go a long way in minimizing the design of this mod. If I can get a rotor that is only 28mm thick then altering the caliper probably won't be necessary. The only other issue might be getting that rotor centered in the caliper because the "hat" might have an offset for a 32mm thick rotor.
Thanks for the link
Very cool - I'm really curious what the price will be on this. If nothing else, it'd be nice to be able to swap rotors without having to tear down the whole hub as you do now.
a small update on this project. While up to my elbows with brake issues I had a chance to do some test fitting.
One small fit issue is that with the larger caliper in place an alloy rim rubs one corner. The steel rims however clear fine. This is due to the fact that a larger rotor will also be part of the upgrade.
The amount of grinding on that edge of the caliper would be about 1/32" if even that. I've got the caliper split apart and there is nothing critical in that area that would be compromised by the grinding.
Since the new calipers take a standard 10mm brake line fitting verses the banjo bolt setup of the stock unit new lines need to be sourced and I think I know where to get some factory ones that will be plug and play.
My next step is to get the dimensions for the new rotor assembly off to DBA to get a price on those.
Generally the hats are made of t6 alloy, to mount the rotr you want from a huge aftermartket selection, where you want it. Heres a UAE version.
A typical caliper adaptor.
Alot of vehicles have good front calipers, 7 series BMW for one, if you search long enough you can find something that will work.
Early 90's toyota crowns [they were called crowns here] had a front caliper that pretty much goes onto rear of cruiser with I think, 65mm piston, vs 45mm, working from memory, which may work well with the 4 pot front your looking at using.
I'm hoping to pull something together that is easy and cheap. Putting these rotors and calipers on the truck mimics my wifes 03 4Runner as they have the same rear calipers as we do.
Darren, do you know what is on the front of the 105s? I'm curious if the fronts were upgraded on those trucks or did they stick with what we have on our 80s.
I've read that 105s do have improved front brakes over the FZJ80s, not sure if it was larger rotor or larger caliper piston or both, but the 5 hole pattern screws up a direct swap.
the 105s are the solid axle version of the 100. Are you sure they are a 5 bolt pattern. Maybe I should go post in that area and see what I can find out.
