Contemplating a knuckle job in the near future on my 85 FJ60. Has anybody figured out a workaround for the issue with brake flex line/hard line union on the backing plate? Basically you have to remove one of the lines in order to get the caliper out of the way and the backing plate off the housing, which means a brake bleed at the end of the job. I'm trying to avoid this just to make it a little less of a PITA.
I know there are after-the fact solutions: backing plate eliminator from Marlin, running a long flex line from the axle to the caliper and bypassing the union. But I am trying not to let this job turn into more of a can of worms than it will already be. Plus I already spent $ on SS lines a couple years ago and don't feel like replacing them with longer rubber lines. (If I knew then what I know now...)
A search gave me the after-the-fact answers - anybody out there have an ingenious solution they want to share? Or is a little brake bleed just going to be part of the knuckle job saga?
Many thanks for any help-
DF
DF
