Front axle rebuild
sorry for the weird question...
I will be cleaning/degreasing the axle and knuckles as I rebuild. It is an exercise in futility to paint everything while torn down?
Depends on your level of OCD. The cleaning part is what takes so long and can double your time budget If you're going through the time and effort to clean it I would definitely throw some quality paint on it NAPA chassis black is quite durable Option.
Harbour freight Parts cleaner and $20 handheld sandblaster goes along way
I'm about to do a complete axle housing removal to replace everything. I'm thinking about going John Deere black or Eastwood chassis black. Haven't decided.
If you live in an area where they salt the roads, probably paint would be a good idea. I always just wipe the outside parts down with all the greasy rags & towels.
Has anyone else experience their axle washers and nuts chewed up? Is this "normal"?
Going to order new ones tomorrow.
If you're the kind of guy to get under there & drop some extra paint on stuff anyhow them by all means paint the parts!
(I do, it's just good practice to keep your stuff maintained - plus you get an eyeball on all places something may be starting to create wear, etc.)
If rusted a bit then POR-15 is my favorite flavor, if you strip it all off then a traditional etching primer & topcoat lasts longer. Duplicolor / VHT is a personal favorite but most all the big names save Krylon give good results.
Rustolium Industrial is a great paint that etches & gloss black is a shiney & hard coating - I keep 2 cans of black just for whatever I weld & acetone, no other prep & it lasts. Comes in the larger cans & they fill them comparatively very full.
Mine looked worse. I took a file to it to clean things up.
My guess is that some shops don't want to buy the right socket size and use an air chisel to get the nut off. Makes you wonder how good of a job they are doing, huh.
I am a bit disappointed with the previous owner, but glad I took it apart. The vehicle has been in the mud and water. There is evidence of water in the hubs. The driver side flange was missing the gasket when I took it apart. There was minor surface rust on the spindle and gasket surface area, but not pitted. Nothing that a bit of steel wool didn't take care of.
I used this:
Poxy Coat®—One Part Epoxy Coating
Got it on Ebay, price was reasonable (~$20/Qt)
Took forever to dry (~2 days) but now it is literally like plastic.
*If you get brake fluid on it rinse immediately with water. Brake fluid will eat thru about anything.
**If you do the brakes get the Napa models with the black coating. They are no extra $ and it's a nice coating.
Trying Ace Hardware's No-Rust Implement paint. Oil based brush on..I'll let u know how it works.
