I’m just days away from starting a frame-off resto-mod on my ‘77 FJ40. I wanted to get an idea on the engine health before teardown to decide if an engine overhaul would also be a part of the restoration, hence I just did a compression check.
It’s a brand new compression tester, I’m at sea-level and the engine was hot. I did the test with wide open throttle, dry and cranked 6 rotations per cylinder. These are the results...
#1. 160
#2. 155
#3. 165
#4. 160
#5. 160
#6. 160
So the burning questions are...
Are these numbers even possible? I thought factory compressions were 160?
I bought the 40 a little under 2 years ago from someone who was flipping it and he didn’t have a lot of its history. It ran really rough initially and I rebuilt the carb, removed all emission equipment, and adjusted the valves about 1000 miles ago. In addition to an oil change I put 1/2 a quart of Marvel Mystery Oil in it. It burns no oil and I’ve put 2000 miles on it since I purchased it. The engine has always seemed strong.
#1. 160
#2. 155
#3. 165
#4. 160
#5. 160
#6. 160
