FRAME DAMAGE (pictures) please help!!
Western North Carolina
Ok, to make a long story short, I believe the front section of my frame is off of another frame. Two frames in one. The section where it is welded has become rusted and damaged. With talk of getting a new engine and using this beast as my primary driver in the fall, what am I to do?
Is this repairable?
Sorry for the links, I couldnt get the small thumbnail to work.
First Pic: Front left rail in front of the axle (damaged on the interior)
http://img482.imageshack.us/my.php?image=dscf03831en.jpg
Second Pic: Outside veiw of right frame rail. You can see where the dude welded a peice of metal to the outer frame wall..
http://img526.imageshack.us/my.php?image=dscf03845ed.jpg
Third Pic: Sideways view of the left side rail. Again, heavy rust damage.
http://img507.imageshack.us/my.php?image=dscf03868lr.jpg
Is this frame salvageable? I hope it is, being 22 and STILL in school doesnt leave me much room for restorations, however Im not a big fan of dying so I will do what needs to be done.
Any advice is greatly appreciated.
Thanks,
Wilson
1 frame
It looks like the same frame.
If it were me, I would get it cleaned up/sand blasted and see what you are working with. I would plate the inside of the frame and tie into the crossmember.
Once you get the inside fixed, I would cut off the c channel on the outside. Plate over the previously repair and burn it tight.
I think it can be repaired. I would if it were mine.
JR
AlaskanWheeler said:
I think some clearer pics are needed;without any wires in the way
The left side picture is bad I know. Thats actually the strap for the camera. I just jumped in and snapped a few quick shots. The FJ40 is being parked at a different location quit a bit away so unfortunatley these mediocre pics will have to do until this weekend.
Frames
VehiculousFJ said:
Is that all we've got?
Jr I appreciate the advice. A buddy of mine has a sand blaster that Im planning on using and hopefully I can find a competent welder somtime soon. Anyone else have any advice about the frame?
It is too bad you live so far from southern AZ. Tim Hill in Avra Valley must have at least 6 frames in good condition. He has another 9 or so that still have bodies and wheels on them, I'm not sure what the shipping would be. If your interested, PM me and I will give you his number.
Posted in the UC section for you about a possible frame. Now that I've seen the pics I think that frame might be able to be saved. I'd be happy to come down and give you a hand I'm in Conway for the summer so Camden is only an hr and a half away. I'll weld anything you want as long as you have some cold :beer: waiting for me when I'm done.
Wow, you guys rock!
I gave a call over to the local 4X4 shop in Lugoff and was told that they wont mess around body off swaps nor would get into any engine swaps. Repairing the frame would be best solution under the circumstances. But can it be done? I also got an incredible donation from Mike even though it has some damage and SBC mounts. I think it would be foolish not to take it off his hands just in case. Man, I wish you guys could see my frame in person. I found some more pics of it hidden in a different folder.
Front view (Dont worry about the hood and the fenders, theyre gettin the boot too)
http://img509.imageshack.us/img509/6105/dscf03907ca.jpg
Another left side inner rail
http://img453.imageshack.us/img453/5471/dscf03874ml.jpg
Just fix it. There is a lot of work involved in replacing the frame. Your still in school. If you get another frame, save it till after you finish your education and have the time and money to fix all the other things you will find when you start getting the body off.
Even the new pics dont make me think it isnt repairable. I think you are overestimating the severity of that rust a little. When you can stick your fingers through the holes like I could then you have a problem. I replaced floor, body mounts, cut out all kinds of body rust. You can bring that back with a some hard work. Clean it up with a grinder or sand blaster and you'll have a much better idea of the condition of the steel though.
LOL
Grind off the old stuff, create some football shaped plates to make it stronger and go to town. Later down the road, replace it!
That frame is not perfect but it is more than repairable..
Mace is right
Mace is right. Get to cleaning.
Swapping frames will be a nightmare for you.
If you plate that frame on the inside and out with 1/4" steel, it will be more than fine.
Maybe beef up the core support/crossmember while your at it with a piece of tubing.
Actually that piece of C-channel will probably be fine, but I would cut it off and start over. I trust my crappy welding over some other idiot's crappy welding.
JR
