I love this idea and want to replace my 7100's. Do you have the part number for the fronts?
I get first dibs on the 7100's![]()
Fox has post top/ eye bottom shocks. Check the 100 tech section.
I had in issue with my rig's frame articulating into the body of the shock and destroying the shock. If and when that happens as you can probably guess the shock is pretty useless until you rebuild and replace the body of the shock. Hopefully it wont be an issue with your rig.
All four shox are the same: 980-14-032-A. They do not come valved at all, so someone will need to set them up for you.
Update: I will need to add more rebound to all four. The compression is good at 30-35, but the rebound needs to be about 90-95 for the really big, fast hits. It's OK otherwise.
