- Joined
- Jul 16, 2006
- Threads
- 36
- Messages
- 87
1. What lift Kit / components did you use? Include Spacers, if any.OME 2.5 Heavy 850/863, purchased from Slee.2. Why did you select that particular lift?Enough lift for most things, but still able to run it with very few modifications. Also wanted to be able to carry tons of gear, etc. without any sagging.3. What tire size are you running?305 x 70 x 16 BFG muds.4. Rim specs - 16x8 w/ "x" backspacingStock rims.5. What caster correction, if any have you used?Have 1" yellow correction bushings that come with Slee 2.5" kit, but have not installed them yet.6. Have you had any rubbing issues?Nope.7. Did you have any Driveline issues? What was the cause and how did you fix it? Nope.8. What is your main on and off-road uses of vehicle?Daily driver, digging in steep muddy conditions, Moab trails, carrying loads of gear and people on camping trips.9. Are you happy with the performance on and off-road your for your use.Amazingly happy.10. What would you do if you were going to do it differently?"If" I end up doing anything differently, it will be to put together a lift and gearing combo that can comfortabley run 35's with no rubbing, driveline issues, etc.11. Any plans on modifying the lift or other related components (Tire size)?Not at this moment. However, I may eventually want to run 35's.
