The factory headlights and fog lights on the 200 series Land Cruiser are just fine and there isn't any reason to change them unless you want to add auxiliary lights in the factory bumper. Choosing to remove the factory fog lights and make a custom mounting plate for Rigid Dually's or any similar cube LED light. This is a write up on what I did to add a couple of extra lights to a stock front bumper cover.
Pictures of fog light opening. The opening measures 4 inches by 10 inches and plenty of room behind the bumper.
After purchasing a 2008 LC, a good companion to the 2003 LC, and wanting to put additional lights up front in place of the fogs. I got a few measurements and originally planned for 3 pairs of LED cubes (6 cubes total) in the factory fog light locations. And they would have fit but there wasn't going to be much room for adjustments while on the vehicle so I left one pair out.
The mounting plate is 4"x4" aluminum angle one quarter inch (1/4) thick. It is bolted directly on top of the aluminum bumper tube. I had to find the proper angle to mount the aluminum bracket and still be able to put the light bolts through without interference front the bumper tube. I took off and put back on the bumper cover 4 or 5 times here and on and off a total of 10 times.
The wiring was real easy by utilizing the harnesses, relay and wires that came with one of the light cubes and I chose to add a 6 post blue sea fuse block. I also used the factory fog light wiring cutting the connections off and adding the Rigid connections with water tight splices to the pair of SAE LED fog lights. Using the fuse block means I don't need the inline fuse from the loom for the spot lights, so it got cut out. Drilled through the firewall and used a rubber gromit. Drilled a hole in one of the blank plates driver left and installed the switch. All of the wires got covered with wiring loom and secured well.
