I had a remote start/keyless entry on my 93, only problem was, it was a one button start, so it was easy to bump in my pocket and start without me even knowing it (it shuts down automatically after 15 minutes), but I was in the habit of leaving the headlight switch in the on position, then they turn off automatically when you open the door to get out. In the case of a accidental remote start, if the switch was in that position it would turn the lights on, but they would never turn off since the door never opened to trigger the relay/switch. Had a dead battery multiple timesMontana Cruiser said:FWIW - I have an aftermarket remote start that also controls the door locks and I can start it and/or unlock the doors from 2+ city blocks away and around a corner ..... makes it nice in the winter leaving home or work to hop into a warm ride. In any case, I have an "antenna" on my windsheild tied into the system, so maybe that helps with the distance. The brand is AstroStart and it was installed by the PO so I dont have any contact info.
Romer said:It's funny, the fob to the chin works, must provide a better transmitter.
97 FZJ80 said:I think the antenna wire is attached to the alarm brain under the driver's seat. Attached an extension to the wire and run it up the A-pillar.
firetruck41 said:I had a remote start/keyless entry on my 93, only problem was, it was a one button start, so it was easy to bump in my pocket and start without me even knowing it (it shuts down automatically after 15 minutes), but I was in the habit of leaving the headlight switch in the on position, then they turn off automatically when you open the door to get out. In the case of a accidental remote start, if the switch was in that position it would turn the lights on, but they would never turn off since the door never opened to trigger the relay/switch. Had a dead battery multiple times!
