Flywheel/Bellhouse gaskets
Durango, CO
Website
www.kindel.com
My flywheel cover has(d) a set of rubber gaskets in it when I took it off. I've tried to preserve them, but they are pretty rotted.
SOR lists these as "030-18A BELLHS GAS SET-5/76-8/87(Discontinued-No longer available)".
What do people use instead?
are you talking about the hole for the clutch fork and the hole for RHD clutch forks?
both of mine are open.
edit i see now.
agian nothing, just bolted the cover in place. "if" i get water in there i want it to have a place to go.
1/4 inch Marine weather strip. Black closed cell high density.....Home depot has a roll 10' long for $4.00
Clean edge's well and peel backing tape off and apply and then bolt back up.
There is a drain hole in the center.
