Fluid Recommedations
Arkansas
I'm getting ready to do the front axle service, change my transfer case fluid along with the rear diff next week on my 80. I'm thinking about going with the Lucas Synthetic Gear Oil for the diffs and transfer case. I have been using a synthetic Valvoline grease for my wheel bearings and will probably use that again but don't know what brand Moly to use for the knuckles. Anyone have any recommendations for these, anything you swear by, anything new on the market you might recommend?
Thanks,
SC
I use Amsoil and Mobil 1 for the gear oil. Valvoline full synthetic Moly grease for the knuckle, NAPA and Advanced Auto parts carry them for $7.50 a pop.
Thanks! That helps allot. Anyone else got any advice?
I in general like the synthetics, but for the diffs, just use available conventional gear oil. The reason is cost. If you get in any significant water, you will likely contaminate your diffs a bit, and the best course of action is to drain and refill when you get home. If you have $60 worth of gear oil in there, you might skip that PM step. If you have $20 worth, it's a lot easier. I buy gear oil in 5 gallon buckets and that keeps the price pretty low.
Now for the transmission, transfer case, etc by all means use synthetics. I have a long term relationship with Mobil1 (20+ years and 8 cars) and would highly recommend that. Lucas/Royal Purple are newcomers and sold on hype. Amsoil/Redline are both proven performers, just a little harder to get than Mobil1.
