flexy flexy
Nice
NICE flexy flexy!
I bet you have those slinky coils...
I want some....
I like the idea of being low, lots of flex & retained coils.
Dig the head lights. Who makes them?
NICE flexy flexy!
I want some....
Yes, the flexy coils make a bit of a difference :cool:
If you type lx450 projector housing into ebay you will find them, I run leds in the low beam and 55w hid in the high beam, big improvement over factory candles ;)
I wonder if any of the original design engineers at big "T" have ever looked at this? I bet they'd be going nuts....in a good way
SNOWY the USA 80.
12" stroke custom Icon 2.5 cdc shocks with our slinky long travel coils, sway bars connected etc.
My Aus version 80 factory turbo getting some extra attention with 2.5 cdc coil overs and bypasses up front, and bypass rears with our slinky long travel coils etc.
Flex pics to come, as that was tonights effort so far.
Rig looks great.^^
So with the current exchange rates being pretty favorable...what would it cost to get some of those slinky springs over to the US?
I already have the shocks: Toyota 80 series TD and petrol Icon Stage 2 Intermediate .
Been trying to figure out how much these would flex vs TJM progressive springs, but haven't quite found a decent # yet.
Yeah, I'm trying to educate myself on these slinky coils also. I'm very curious of them. Is there any links that you can post up. To show how they work, what sizes they come in & where to get them. Does anyone sell them in the US? I like the theroy of a slinky coil that stays captured or retained but yet stay low. The closest I have come across is the TJM 50mm coil, but have heard they can't handle extra weight.
I'm mainly wanting a 2" lift coil. I currently have 851/860 & are unseating when at full flex with shocks longer than the L shock length meaning 26.5" to be exact.
These coils are something we have had made since around 2005.
They were our design, and we went through many variations to get something that would last, and work ho we wanted them, which was to run tapered wire to change the coil rate where we needed it in the spring design.
There were afew variations by others over the years, but issues when they tried to make similar flexy style coils cheaper by not tapering the wire showed what we found in testing, that the coils would continue to sag, and the coils would snap at the active to dead coil section when cycled. Anyone who has designed coils would know theres a computer program you can use to determine coil design stress levels, and without tapering the wire, its impossible to get the stress level for the coil out of the red.
Our design, to explain simply, runs front coil rate similar to 851, but we went slighty softer, but slightly taller free height at ride height, so for the same weight, the ride height is the same at its rating, but the vehicle rides better unloaded.
The top "slinky" part of the coil goes to a 160 lb rate so when the vehicle is on tippy toes, the softer coil stops the car from tipping around on the last 4" or so of travel, because the coils will compress more easily, keeping the vehicle more stable at its limits.
Our rear coils use the same 160 lb rate on top, and we do the same design, using rates similar to 863 or 864 in the rear, but again, slightly taller free height at ride height, but slightly softer rate, for better unloaded ride quality.
With these kits, we have had Icon Vehicle Dynamics make us 2.5 CDC adjustable shocks specific length and valving to suit, that work with these coils.
We also do a firmer rear sway bar, which helps prevent the roll steer the 80 is known for in the rear, without really restricting travel.
This design [fronts pictured] keeps the coils captive using a 31" shock in the rear and 28" front with only a small bump spacer in the rear for the compressed length, with the sway bar links and spacers, longer brake lines etc.
This has been our slinky long travel kit, for nearly 10 years, our first coils are still out there, still sitting where they should.
We have been testing this set up in the U.S.A in probably one of the most wheeled 80's in the world, and looking forward to some more feedback shortly, as we look to get to market.
I believe 780 was the Metalcloak ramp score, sway bars on, HD front coils, intermediate rears.
We do similar kits for FJ Cruiser 100 and 200 series as well with similar coil designs.
Hope that explanation on how they work helps :cheers:
Wow, so if i read that correct, your coils sit at the 2.5" level & can be retaind with a 28" shock in the front & a 31" in rear. A stronger rear sway bar with some small spacers.
Thanks.
How do you get the front to drop out below 27" without hitting tie rod ends?
sounds about right, my coils are retained with a 29" open length shock
What set up are you using in the front to yield flex to get full travel of a 28" shock. I have removed my springs, diconnected sway bars & removed front control arm bolts to get to 27" + at that point the tie rod is hitting the control arm while in tight turns. I'm just curious as to what you have done to eliminate the tie rod from hitting.
You mean it hits on the control arms locating the diff when articulated and turned on the lock?
The steering arms are forged, and we fix that by strapping the housing to the four poster in the car, and putting a bottle jack under the arm, and jacking it up slightly to improve the clearance.
You will be surprised how easy they bend a little.
