flexy flexy
cairns
Website
www.4x4palyfnq.com
hey guys thought id through up some flex shots from this arvo
nice!! did you disconnect any sway bars?
I'll throw in a couple. 6" Slee system, 2" Roger Brown body lift, 38.5" tires.
Before the Upol coating, same set-up.
09-27-08 11:07 PMlandcruisers4evernice!! did you disconnect any sway bars?
yeah mate had all the sway bars disconnected
09-28-08 02:34 AMtheside00Nice cruiser
what suspension are you running there?
ahh its a 3'' lift with 5'' shocks and 2'' body lift and quick disconnect sway bars. the shocks i run are oz tecks and the springs im not sure was there when i got it and running 285 bfg muddies
MsgGrunt,
How do you like those michelins? I used to have a set of 54's I was going to use on a beater chev, but never had the chance to so I sold them. They had the same lug pattern as yours.
I like the green paint, is that bed liner?
I like the tires. The coating is U-Pol bedliner tinted with factory 40th Emerald green.
Wow when I first say this I though. Wow cruiser dan got himself a diesel 80. Had to double check the spelling of the screen name:whoops:
Nice 80 :cheers:
What did you do for your quick release sway bars? Something that you did yourself, or is a kit of som sort?
Oh ya...MAD flex & SWEETrig! :grinpimp:
tONy
09-30-08 10:40 AMMr. MoMWhat did you do for your quick release sway bars? Something that you did yourself, or is a kit of som sort?
tONy 09-30-08 09:43 AMlt1fireWow when I first say this I though. Wow cruiser dan got himself a diesel 80. Had to double check the spelling of the screen name:whoops:
Nice 80 :cheers:
first thanks guys and as for the sway bar disconect its a set up iv made myself that works very well takes about 2min to disconnect the front and about 30sec to do the rear
Any pix of the front and rear sray bar dis-connects?
Thanks
tONy
