flexy flexy
Interesting...so, the L shocks are how long at full extension? Full Compression? And, when you say adapt the top to eye instead of pin, are you recommending this for both front and rear? And, is there adapters already made to do this or do I need to fab them? Do I still want to use the lower bumpstop extensions or remove those, as well, to maximize up travel? Or, keep them because of the larger 37" tire size?
Chris
This is the information I've gathered.
Code:
Model			Min	Max	Range		Upper	Lower
N73			13.57	23.40	09.83		Stud	Stud
N74E			14.57	24.40	09.83		Stud	Eye
N73L			15.23	26.26	11.03		Stud	Stud
N74L			15.23	26.26	11.03		Stud	Eye
While I personally measured the shorter shocks I've only been able to find "reported" info for the longer shocks, and some of it conflicts. So those numbers may not be 100% accurate but they should be close.
As Walking Eagle suggested with a 6" lift you will have very little droop as you will sit towards the fully extended side of the shock.
As an example, the Pro Comp 14" travel shocks have a min of 18.82" and a max of 32.83". Now that's not apples to apples as you will have to create an adapter which may move the upper shock mount up or down an inch or more. Anyway, The range of a 14" travel shock will be much more appropriate to a 6" lift than the range of an 11" travel shock. 3" makes a surprisingly large difference (that's what she said!).
I like bumping old threads...
Nicely done. Do you have LCP's swaybar disconnect kit? If so, do you notice much of a difference with it disconnected? I have yet to install mine.
I like running the sway bar connected with the pin pulled. It just feels better. More free with less sway.
Just watch you tie rod the 1st couple times out. Mine hits on hard turns.
30" with swaybars disconnected, narrowed control arms, 850J/863, "L" shocks
img_6834-jpg.837856
Will you show pics of the narrowed control arms & where is the 30" measured from?
Correct me but the L shock ext. is 26.3"
30" is measured to the bottom of the tire on the forks with all others tires touching. The arms and bushings were narrowed where the bushing set in the factory brackets only. With swaybars connected the measurement was 26" posted HERE
As for the measurement of the shocks I will just believe you, I dont know.
Haven't measured yet but I think it's a lot
Now if you could get the shocks to yield that flex.... that would be mighty fine.
Is that a 3 link? Can't see.
Put tires on it and you dont have the clearance to do that :flipoff2:
I do look forward to the end results. The mod looks to be awesome if its anything like the prototype:cool:
This was just a quick test, but I'll be cutting what I need to maximize travel. Inner fender sheet metal is the least of my concerns :)
Thank you.
I will eventually buy your disconnect just for the heck of it.
I have read & have see posts from you & Tools R Us all the way back to 2006. I'm sure you know what your doing.
Do you have pics of your ride twisted up opposite corners all V'd out?
I dont see the panhard in the pictures are you able to run without one?
I'm envious...
I can only hope to find time to do a full scale build some day.
It will be a streached fj40.
Thank you.
I have read & have see post from you & Tools R Us all the way back to 2006. I'm sure you know what your doing.
Sounds like you have tools and skills, they are easy to make.
Actually my first set of disconnects was in 2004 HERE
That was then running 37's
This is now on 35's
Not the same 80 :doh:
