Flex plate??
Chapin, South Carolina
I've got a 93 80 series I picked up a couple a months ago. Since then I have gone through the motor, fresh tune up all new hoses under the hood including the pos PHH. It's got 267,00 miles and it's well documented on maintenance and repairs. It was a single owner up until I got it. The issues I have left to address before I start to really modify it are oil pan leaks, crank seal leak and I've got a start noise. I've already replaced the starter with little positive results. My local mechanic says the flex plate is warped. I've never seen this on a 212 hp vehicle. I've seen high horse power motors tear up fly wheels but never something like this. Any thoughts or suggestions before I have the trans pulled would be appreciated. The noise is almost like you're holding on to the key to long but it's very subtle and it only happens every now and then.
Is the noise a rattling sound that lasts 1-2 seconds when you first start up a cold engine, or is it more of a metallic grinding noise when you start the engine and release the key?
Doesn't seem to be a big enough problem to justify puling the tranny, IMO.
It's metallic in sound, Mighty690 I agree. It just gets a little attention from bystanders from time to time. This is going to be a mild trail rig as my 11 year old daughter and I work on it together and I plan on handing her the keys when she can drive. I had another mechanic friend tell me to ride it out at worse I'd have to replace the starter every few years, and when I pulled the old starter there wasn't significant damage to the bendix, actually looked pretty good but it was a replacement about 3 years old according to the records. I guess I just don't want an issue that could leave us stranded as I camp with my girls a good bit. Thanks for the input!
Webster77: When does the noise occur, every time you start the engine, on a hot restart, cold start?? How long does it last??
I had the same sound issue. I seriously thought I had a big issue too. I changed the belts to OEM and tensioned them properly (tighter) and haven't heard the noise since. Very cheap first option.
It just has that mettalic noise and only occurs at startup, it doesn't sound like a belt and I've used a lot of belt dressing because I thought there was an issue there, but I will give that a try on the exchange of the belts. I also thought the power steering pump was an issue but it's been replaced also .
There is a typical start up rattle from the 1FZFE, lasts 1-2 seconds, sounds a bit like a handful of nuts and bolts bouncing around in a tin can, occurs after the vehicle has sat overnight most commonly. It's caused by the timing chain before the timing chain tensioner fills with engine oil and extends taking the slack out of the chain. The fix is an oil filter with a good anti-drainback valve like a Mobil 1 filter, and/or a heavier viscosity oil, and/or mounting the oil filter remotely or using a 90 degree oil filter adapter where the oil filter is now upside down; it then cannot drain out no matter how long the truck sits.
The 1FZFE power steering pump (93-97) often makes a whining noise, worse in cold weather; mine has done that for the last 200,000 miles, less noticable after switching to Mobil DTE 24 hydraulic fluid. Others have added a teaspoon of Downey fabric softener to quiet the pump.
Noise from the starter (pinion gear clashing with the flexplate teeth) is a very loud and unmistakable grinding scrrrreeeech. The fix usually is a new/reman'd Denso/Toyota starter particularly if the current starter is a parts store reman'd unit.
The alternator belts can make a mild squeeking sound, fixed by using the correct Toyota matched set of belts adjusted properly.
I know this isn't on an 80 but I had my ignition switch go bad and leave the starter engaged it would sound like you held the key and then it would quit. I only heard it a few times before I took the truck out and it was so loud I couldn't hear the noise over the supercharger and the exhaust and it smoked the starter. Getting to my point, maybe check your ignition switch if you really feel it's starter related and you already put a new starter in.
Looks like you've got a good looking rig. That color is my personal favorite. Camping, Scouts and Baja trips with my three kids and wife and dog is how I came to 80s ownership. (GMC Suburban couldn't handle repeated Baja trips.) What a great time it has been. Now I know too much about the 80 series to move on elsewhere! And, I've never been stranded.
You might want to look at the bearing for the bendix in the starter itself. My previous life as a Jeep owner, I know I have done my 12 step process, the starter had the bendix bearing was taking a dump and would sound similar to what your talking about.
I've owned an Fj40 before and I like the comfort and capability of the 80. I was a jeep guy before but I was so impressed on well built the FJ40 was that I had to make that my next endeavor. The LC I picked up is awesome on how well it's been maintained. The interior is immaculate and it's been repainted so it looks like it came off the show room floor. Axles have been rebuilt, birfields and all, sealsare great. Just has this noise and a few oil leaks. I've got a 2 inch lift and these tires waiting, just trying to take care of all the important things first. I want this thing to be reliable, but I know it's going to be s beast when we're finished with it!
Talked to a mechanic friend of mine today who said he changed the starter on a 97 80 series that was making an identical noise to mine. I recently changed my starter with what was on there when I purchased it, the 1.4. He installed the 2.2 on this one and the noise went away, could that be my problem not having the stronger starter of the two??? Any thoughts?
