Me and my dad are trying to put E-Locker axels from a fj80 and put them in our 1995 fzj80 that did not come with E-lockers from the factory. Dose my dad's 80 have the E-Locker wiring harness in it? Would It be missing anything that I would need to get?
Yes, it is missing many things. Check FAQ's. Off the top of my head
ECU
Dial (switch)
dash bulbs x2
front and rear actuator wiring harness
Sill harness if you don't want to make one.
Main floor harness (see above)
ECU
Dial (switch)
dash bulbs x2
You only really need the harness at the elockers and you can still buy them from Toyota for about $30 each (I think Marlin and Inchworm both sell them as well). It's probably easier to run the rest of the wiring yourself. I used 6 conductor trailor wiring when I installed two elockers in my 85 4Runner. I used an FZJ80 elocker ECU and switch so you might find the write-up helpful.
