FJ80 Axles Are Simple, Right???
Central Alabama
Website
www.trailwerx.com
So after having taken apart Toyota and Suzuki solid axles so many times, that I thought I could self label myself a certified expert, I must hang my head in defeat, and post a “WTF is going on here” thread... Begging for help...
The problem:
Short side front will NOT quit leaking gear dope into the knuckle.
What I’ve done thus far:
2 years ago I swapped in e locked axles. When I got them, they looked like hell, so I broke them all the way down and rebuilt them completely. All new seals, bearings, etc... Except the diffs. Even sand blasted and painted the housings. Tried to get them as uncrusty and serviceable as possible for a lifetime of smiles.
I’ve since noticed a small leak of gear dope on the bottom kingpin, but since I was planning on rebuilding the diffs later, just noted it in the “to be addressed later” part of my brain.
Recently:
I finally got around to re-gearing/rebuilding the diffs, and installing new birfs (mine were clicking), and it was time to address that leaking inner axle seal. Even though it had a new one, I figured maybe I knocked the spring out of it or something, and just went ahead and installed a new one.
Swapped birfs, and noticed the machined part of the inner shaft that rides on the inner axle seal was majorly grooved on both sides. Found some take out inners on Mud, figured I had found the cause of the leak.
Nope. New seals, nice inners that aren’t groved out, and my leak is back... On the short side. The easy side!!!
What could be causing this, that I am missing?
On the steering arm, did you use a dead blow hammer and hit it while torquing in order to make sure it got seated?
Did you clean out the axle vent hose assembly?
On the left end top of the axle housing is a vent with a hose that goes to.a box on the frame. If the fitting, hose, or box is plugged, it will allow the housing to pressurize and push gear oil into the knuckles.
Make sure you remove the fitting and clear the hole in the axle. My fitting, hole, and hose were plugged with solidified gear oil.
This is the time to buy 6ft of 1/4" fuel hose, 3 hose clamps, and a cheap 1/4" fuel filter and extend your axle breather up to the power brake booster.
No on the deadblow. Everything there seemed to assemble easily. Wouldn’t a wonky seated kingpin create some nasty driveline vibrations though?
Good idea on the vent. I’ll check that next. You think a clogged vent would pressurize the short side first?
Mine happened to leak from the short side first. That's how I know this to be true.
A loose arm will not cause vibration. It causes slightly loose steering. I drove LOTS of miles on a steering arm that one stud was sheared, two more had fallen out, and the fourth was hanging by 3 threads less than finger tight. I was VERY lucky it didn't come off and wreck on the interstate. The pin up from the bottom keeps it centered.
Pretty sure all that is correct, but I haven’t been that far in since original assembly.
Even if the rubber ring and metal ring are backwards, I think that would just cause grease to push out, and not cause the inner seal to leak.
Did you stack the knuckle seals, felt, rubber, and steel, in the right order?
If you're going back in there again, I'd press the new inner seal deeper so you KNOW it's riding on a fresh section of axle. Wit's End sells a seal driver tool for this purpose.
The vents should definitely be looked at, they are likely a contributor to the leak as well.
Another possible cause is early flanges with later birfields. The shorter/thinner flange off an earlier axle plus the longer splined section of a later birfield can allow the birf/axle to move around a good bit which can lead to leaking of the gear oil seal on the axle. You'll also get dust caps knocked off regularly.
  • Like
Reactions: RFB
Missing or incorrect shim(s) under steering arms?
Bent housing?
I think the shims are correct, but I will check them. The only way I really know to check them is with the pull gauge. When I rebuilt the axle, I put new ones in, and just matched the depth to the ones removed.
I hope it’s not a bent housing, but the thought has crossed my mind. I’m going to assume no, because everything seemd to align good on the rack after the lift.
This hasn’t had mismatched birfs before now (assuming that maybe the new ones could be of a longer variant). Only mention because the leak was there pre new birf install.
There is an SST for centering and shimming the knuckle on the axle. Usually only necessary if you’ve swapped knuckles or lost the factory shims. The tool is not cheap. If there is a local Toyota club try to contact them. They may have one you can use.
Would knuckle shins/tension cause an innner axle leak though?
Maybe the steering stops are letting the wheels turn too far? I would think that would cause either a birf being pulled from the retainer ring, or a popped flange cap though.
Do you know if the knuckle is not centered up/down on the ball. Too many shims on the top or bottom will move the shaft up or downwards and create a bit of a gap as the shaft stretches the seal in one direction. There is a centering tool for this.
what he said.
Ah! That makes sense.... That sounds very possiblly what’s going on!
Try putting some RTV on the outside of the seal when you press it in. Also make sure you rub/lube the seal itself (and I’m sure the axle itself wouldn’t hurt) with some diff lube when you slide it in to make sure the axle doesn’t “grab” the seal and rip anything.
But, my bet is with the vent line being clogged. If you’re fooling with it, it might be a good time to go ahead and extend the breather into the engine bay anyways. The ARB kit looks pretty sweet, but at $70+/- I think $5 worth of hose and a cheap clamp will work for me
Axle vent is clear.
Been thinking about this, and I think considering the symptoms, it has to be the knuckle alignment.
Anyone know the cheapest place to get the alignment tool? They seem to vary in price greatly.
And Jesus, are they expensive, for what they are...
The knuckle alignment thing is for earlier axles, the later '80 axle only uses shims to set preload. What brand of seals were used?
