Must feel rewarding to be "published" huh?
Just rebuilt my pump and it was helpful to have this plus the FSM. A few bits I thought I'd throw in for others reference:Does anyone know the part number of the original shaft bearing like NSK 6203XX (from the seal), or a photo of same?
under the spring is the rear plate. i had to tap on the desk to get the plate and rotor/vane assembly to fall out.
I just took apart an OEM pump and the bearing had metal seals on both sides and marked 6203Z
According to the bearing spec book, a bearing p/n showing only (1) Z indicates the bearing only has a shield on one side. Check me on that THX.
Hi, any other suggestions to remove the rear plate? I have taped like crazy the pump and won't come out, I taped lightly but many times and with force, the pump is not deformed or anything like that just the rear plate wont come out.
I have already removed the plates one time replaced the o-rings, the seal and the bearing but installed wrong the first plate (the one closet to the bearing is not fully seated in place) so all the plates are to high and the pump won't close of course.
This is driving me crazy I don't know what else to do.
Thanks.
Did you figure this out yet? My rear plate was stuck pretty good so I removed the ring, plugged the hp outlet then 'blew' the plate by pressurising the pump with a compressor through the suction port. Worked really well, just make sure to 'aim' the back of the pump into a rag away from anything important
Matt
