Fj62 ome install question. can’t get it in the hole
denver
I started to install my ome kit on the weekend. Lots of issues with frozen pins and bushings getting the old leafs off all of the bolts broke loose rather easy though. Used a lot of heat with a map torch and a 3lb hand sledgehammer. The front end went fine and the pin in the middle of the leaf lined up with the axle mount hole after some maneuvering, wasn’t to hard. I’m now having major issues with the back suspension and the pin lining up with the hole on the axle leaf mount. I’ve tried everything I can think of. I Hooked up both the fixed frame end and the shackle end and tried to line it up and it is off by half an inch the axle needs to move forward or the leaf needs to move back and neither will budge. I tried undoing the u bolts on the other rear oem leaf to free up some axle movement as recommend by the tech at cruiser outfitters and it still won’t line up for anything. I then manged to line the pin in the axle perch with both end of the leaf detached fixed the u bolts and tried to hook the ends back up and now they are way out of alignment. So either the leafs ends are hooked up and the axle and leaf won’t line up or I can get the axle and leaf lined up without the leaf ends fixed but the are out of whack. I’m at a loss for ideas I’ve had two other brains working with me and we are stumped. Anybody else out there have a trick for this problem. Please help I have a useles cruiser taking up my garage.
If I understand your problem, use a ratchet strap to get things lined up. Easy peasy.
  • Like
Reactions: OSS
Yes,
You need more leverage. The axle isn't all that easy to move because you've got a grease hydro lock in the driveshaft yoke preventing it from sliding easily. Try removing the slip yoke grease zerk.
I've done my fair share of leaf pack wrestling too. The only way I found I could do it (though it's never easy) was to mount the front of the spring to the frame hanger first. That's the starting point. Then lift up the rear of the spring until the midpoint is near the axle housing, then as @John McVicker mentioned, use a ratchet strap to pull the axle housing into position. If you don't have a ratchet strap, you can use rope and make a Spanish Windless or whatever to leverage the axle into position. I don't know how you'd be able to do it without a HiLift jack either.
Once the front and ubolts are tight, the rear of the spring needs to be leveraged down to reach the shackle. I used a long thick aluminum pipe strapped on to the spring to bend it down far enough to get the shackle attached. Kinda tricky by yourself. Or a long 4x4 piece of wood would work. You'll definitely need some sort of leverage to bend the spring down.
Yep use a ratchet strap or a come along. Pretty standard deal, I’ve done it several times
X2 on removing the zerk.
Could someone point out where the zerk is I have never even heard of it. I’m still kinda green obviously lol. Pics would be helpful. This sounds like the easiest option.
Few things,
1. unbolt your ebrake cable from the axle housing (2 bolts on top)
2. unhook your drive shaft (easier to move the axle around and line it up)
3. Sure you have the leaf springs the correct way around? One side is longer than the other.
After disconnecting everything above, I did not have to fight anything and no ratchet straps were needed. The axle just lined up and everything bolted into place.
The front was harder for me. the rear was a breeze.
I just did this. Here is what I did. Put a large (about 2ft) pry bar in the rear shackle. the handle of the pry bar low to the ground near the wheel and about 3 inches of the pry bar end pointing out the back of the shacke and upward. Lay with your back on the ground, head back near the shackle and put your foot on the wheel well body of the truck for leverage. Pull the pry bar handle rearward. This will flex the spring. This pulls the spring back and the pin will drop in the hole. Make sure the spring is pinned at the front eye. Make sure the axle bolts are plenty loose.
Yea I have them oriented correctly, frame end and shackle end. I’m gonna try some of the tips here need to go get some ratchet straps. Hope I have a positive update for you later tonight. Thanks guys.
Thank you all very much!! I removed the zerk and she slid right into place. 33’s in a week or two, I’m already loving the stance!!
The rear leafs are sided. They are labeled A or B. If you have two A's, you may (or may not) end up with a lean to the right. If you have an A and a B, put the B on the right side.
Did you install the centering bushings where the rubber isolator pads used to be? Did you reinstall the isolators and steel hat channels on the rear axle. They MUST be left off and the centering bushings MUST be used.
I had identical rear leafs I checked with Kurt at cruiser outfitters they weren’t labeled a or b both had + signs he said I was good to go. I did install the centering bushing on top of the leaf, but left off the steel hat as recommended.
I'm having the same issue and this thread helps but leaves me with a question. Does the rear axle end up getting pulled forward so wheels/tires aren't centered in the wheel well anymore?
