FJ62 Ignition Problem - Now I'm spending wildly...
clean the coil hold down bolts first, and run that ground from the ignitor case to a good ground.
There was 2 cases of bad ground melting rotors inside the dist cap here in the past couple months, don't add another.
Toyotas use switched grounds, instead of switched hots. That is why there is such a tiny wire thru the key ignition, back to starter.
There is also a starting relay, a re-settable breaker in your main box under steering wheel. after grounding ignitor, try re-setting that with a paperclip, and should work fine for another decade...
ToolsRus points out
"The 1FZ rigs have a ground wire that goes from the fender well to the coil bracket, the intake and the motor lifting bracket, so well grounded."
@morganism it is this screw you're suggesting me to connect to body, right?
Now I've connected that screw directly to the battery and still no result. I saw this picture in a different thread and tested if the top right and left plugs in the diagnose plug had 12V. None of them had. Also I have no engine light.
This indicates that it's the EFI main relay. However... The plug that goes to the high tension coil has 12V. Just tested that too. It doesn't make sense to me anymore. I've gone blind now, and need a second opinion...
check the wires off your positive battery terminal , there is a group of wires that run off it that are in a plastic junction capsule , can not remember the proper name of it but there is a short black wire for ignition could be broken on the inside , don t ask me how I know but that was my problem ...
I don't follow. Isn't the rotor in the distributor? Because the problem is before the distributor. I'm thinking (based on advice) the EFI relay og the Main relay which was warm when I took it out.
The pickups below the rotor need to pass the pickup to trigger the coil to collapse and send the charge. If rotor isn't turning then it won't send signal. If rotor doesnt turn, then dist gear is broken, and i don't know, but i think that will stop your oil pump from working, so it may well run dry
also check the connectors at the edge of the ECU board, it may not be getting good contact
Emissions Help Needed!
Bad Signal Generator/Pick-Up Coil in the Distributor?
Open Circuit Relay
@Michael Hanson I checked the fusible link (which has been a headache before), and it's fine! But I do not have an engine light.
Curious if any of you found the problem. This happened to me and it was a bad distributor pickup. It was intermittent until it just died, it didn't throw any codes on the CEL.
I had this exact same issue. My 88 FJ62 would run great and then all of a sudden die. It would turn over and not start. Eventually I could get it back started again most of the time. It turned out to be a corroded temp sensor at the thermostat. I ASSUME that this is the water temp sensor for the fuel injection and when it is not connected the FI doesnt fire. I figure it out when I got the car running and started jiggling wires looking for something loose, as soon as I touch that wire it died. Replaced the connector and it has fired every time since. Lucky find for me. Hope it helps someone else!
Hey everyone thanks for all your great input.
@Michael Hanson I checked the fusible link by measuring the plug on the picture below. It connects to the ignition coil, and it has 12V.
@Wanna Cruz Thanks, I just printed the pages. What I get from them is that I need to do a thorough check of the ECU because I have no Check Engine Light.
@morganism Yes I did clean the hold-down bolts, but I didn't connect them to the negative pole of the battery. I'll try that next.
@73tlcv8 Nope, haven't found it yet, but I am going to. That's a promise! I just drove the car from LA to Argentina and shipped it to Denmark. There is no way it's not getting back on the road :-)
The story of the car is that I just received it from the shipping company. It's been underway for two months. I imagine that when it has gone through customs, they have checked it pretty thoroughly and probably pulled some cables aside.
That is the only reason that makes sense to me. So I will do a thorough check of the ECU (measure every single pin), and every connection too. The car hasn't moved besides from being driven on the ship and off the ship. And the guys working at the port have probably cranked it a million times with external power because the battery was dead. Something might be broken from that. I have no Check Engine light, so as I understand it, it doesn't make sense to check anything else but the ECU until I have a check engine light. Agree?
Next I'll try:
1. Connect the hold down bolts of the ignition coil to the negative pole of the battery.
2. Do the test from the 3FE repair manual in chapter FI28. Basically I will check every single terminal switch in connected to the ECU. Hopefully that'll narrow it down for me.
D1RCSYuVBHgnnBGgfyKXITIlHHZX3C-0oTWUvnCFHfa_agmw9NzPR7zd-7XtvOoAc9clJarlhOgucvQc6-i_BLZIMDrkfUv0CxJF4xwPqNW6iQN36kRDVxEpYYWsDoWScHyLIn_l
SNYgEQr_2WLLfninRop20QDhw5MXJeVscV2uTZ9YEZHA5f2UIyreFDHVeKc39BJV7oJ8myseJrmantaEv5ZtRuNBEFcxDHXSO32oc6hR2Zraq5IIi_eutnNvYiePEPAKQBrOtBTt
