I will apologize in advance for not spending time searching previous threads, I suck at it and really don't have time, I need help.
Parked it and went to start it 1 hour later, motor turns over, but won't start. Tail pipe smells like gas, pretty sure it's getting gas. EFI relay clicks, does this mean it's working?
No spark.
I used a screwdriver in the plug wire and coil wire to ground and turned the motor over, no spark. I've recently replaced cap and rotor because I drove through high water and it got fouled out, not sure this is important but could be a lead..
while under the hood I noticed the wire connected to the cruise control module was not connected. It goes to a Y that has wires that goes back to the coil. It's most likely I left this wire loose when I pulled the cruise control module out months ago. If it came loose, are there wires in that Y that could have fried something, the coil, or something else?
What does the relay behind the glove box do? I get no power to that on any terminal and suspect it may be a Transmission relay or something..
there are 2 electrical plugs on my coil. one has 2 wires, I didn't check that one. the other plug has 4 or 5 wires on it. One of them has 12 volts to it. I used an Ohm meter to check coil wire, it's fine.
My 80 is parked in a high risk crime part of town at my buddies house, I have a Napa coil on order for tomorrow morning, but I though you guys might have some other ideas.
I'm short on time because my 'other' truck 03 s10, is metal to metal on the brakes, I have the parts and am about to do this tonight, already 8:20pm my time and I have to be somewhere 40miles across town in the morning.
Thanks for any and all suggestions, I am mechanically inclined and my feeling is that it is a coil, but I wanted to pass it through the 80 think tank
I have an FSM and a FSM electrical book, however, I've misplaced the latter..
Again, sorry for not spending/wasting my time searching, I'm hoping for some quick advise.
Thanks you guys rock.
Andrew
ps, if you'll excuse me for my not searching I'll post some pics of why I hate mud from last weekend when I get back on the road..
a
No spark.
Andrew
a
