So it's been awhile since I posted something useful for the community. Actually this might not be useful, but I'm trying to give back ; - )
My last post was the beauty shots of my restored FJ60. Anyway the improvements moved to the ragged out original FJ60 steering box. After researching, I figured I'd take the leap and upgrade the box to the beefier FJ80 steering gear box. This is a heavier duty box and it improved the steering feel and overall responsiveness of my rig. I'm running 33" with a 3 1/2 lift and it's a notice lee improvement. Not SOA, but it's still cranking some heavy tires and it seems to just work better. Also I'm still running my 60 steering pump, all fitting match up perfectly and the pump seems to keep up with the 80 box just fine.
Ok so the box deinstall is easy as long as you have a good quality puller for the bitchy idler arm. And as you can see this project led to replacing the u joints in the column. 220k and they were pretty sloppy.
- Talk with Cruiser Dan at Toyota, NM, very nice guy and he will set you up with the correct U-joints. Trust me, when ordering the replacement u-joints for the column go with the 1975 TOYOTA COROLLA 1.2L Universal Joint. THERE IS A POST STATING 1.6L Corolla...these are flat out wrong and unless you like being annoyed go ahead and try them, they won't fit. Too big! Go with the 1.2L motor and you won't get stuck with a column on your bench for a week. Also be very gentle when pressing the old ones out, I ended up cutting mine and this made the caps pop out so much easier (I'm not a big u joint replacement guy so maybe that the way your supposed to do it). When installing the new ones be careful to not overpress the caps into the ends...you will load the joint and it will not move correctly. Then you have to futz with the caps to balance the pressure on them which can be frustrating. If you not sure on the joint part find a local old time mechanic and get him to help. Probably take them 15 minutes to do both.
SIDE NOT FOR THOSE THINKING OF de-vaning your air pump. When your original box it out you can literally remove the airpump in about 10 minutes. Unbolt it and pull it thru the gaping hole where the steering box was. Ez mod and less hassle from doing it up top.
Ok next, you need a decent FJ80 steering box. I got mine from cruiserparts.net , a bit pricey but the box was tight with no leaks so pay the extra $100. and save yourself the hassle of a sloppy box (I could probably word that differently).
I was admittedly nervous tackling this conversion, but thankfully everything about the FJ80 box works for our 60's. Bolt pattern, Input and output splines are exactly the same and your idler arm will work perfectly as well since the box is the same dimension at the output shaft. There is one exception, the top left corner (10-11oclock) is beefier so you will need to cut a small arc out of the inner fender liner. Ez with the right tool, even a dremel would work but u will probably eat a few blades (damn Toyota makes a stout fender liner !) . As you can see from the pic I went a bit high, but I wanted clearance to the the adjustment nut as well.
Next, reinstalling the column shaft. The input spline shaft on my truck was slightly longer than it needed to be, but after cleaning it up I was able to get to to slide easily past it original stop point. So in hindsight I really didn't need to pop the cap from the slip tube for the column since the shaft doesn't extend that close to the backside of the cap (this will get a runner boot in the near future) . See the pic and it will make sense.
Also, you will need to cut back the tin dust cover to clear the beefier input shaft are of the 80 box. If you've made it this far what's another grinder wheel!
So after you've rechecked all you bolts you should be good to go.
Oh, another trick I stumbled across is the LANDCRUISER emblem in our stock steering wheel pops right out. So when you need to access the nut holding on the wheel to straighten your wheel (because it will most likely have moved while you do this mod, esp if you pull your column and go deep) this is a huge time saver.
Ok I hope this is a useful to those thinking about doing this conversion. On a scale of 1-10 I'd give this a 6 or 7. Take pictures, take your time, fix whatever else is worn while your in there and you will be a happy camper with a better steering 60.
