Hey
So i have a 1984 fj45 land cruiser,
I cant get it to idle nicely.
I can get it to run but i hear a popping noise from the exhaust.
Every so often it will back fire on decelerating
and rarely it will backfire through the carb.
Now.. i have tried to set the ignition timing when i have it close to idiling at 950rpm it wobbles 940-1000 i cant get it to stay still at which time i can see the 'bb' but it wobbles with the revs around the pin. For some reason retarding and advancing the engine doesn't seem to change where the 'bb' sits.
At 1000rpm the dwell angle sits at 44-45 but when i apply the throttle it comes to 41 where it should be. My question is should the dwell stay constant at 41????
What can cause the engine to wobble its revs???
The vacuum from the distributor when applied to the carb the revs pick up so i assume it is working properly.
Any help will be very much appreciated.
Thank you in advanced.
