FJ43?
Definitely a 1979 based on VIN and valve cover. Yes 416 is dune beige, just like my 1980 FJ43. I’d be concerned about dirt, sand and/or water getting in the head with that chipped oil cap as noted by Matt. Looks like it was painted at least twice given all the beige over spray in the engine compartment. Still worth checking out though.
LOL. Just read your post again. That's definitely not beige over spray in the engine compartment. That's Riyadh dust/mud! We live with that stuff everywhere.
Funny, Riyadh dust/mud everywhere does make sense.
416 Dune beige is the best color!
Did you buy it?
I hope he did , barring the oil cap inspection it looked like a clean truck , that was just missing alot of small pieces from
local Members of the TEq Bandits Car Club ......... 🤣
Haven’t been able to contact the owner. It’s Ramadan so a lot of people are either gone or keeping nocturnal hours. Going to look at it again tomorrow and to take more photos.
Few photos from undernearth around the transmission and transfer case. Rear axle to see if it has a hand brake cable. Backing plate of the front axle would tell if it has disc brakes or not. Not sure when that market got disc brakes. We got them with the 76 model and Australia was the 83 model. The 8/80 split transfer case had the larger thread in the shifter like the 60 series. While not like the 60 series the shift knob on the 40 series used a fatter knob unlike the pre 8/80. Photos of that too will help determine if it has a five speed.
Will do. The doors are open but I won't be able to run through the gears to test for 5 speed. They have a lock on the brake and clutch pedal levers; never seen one like it before. The frame looked almost new with no welding and no rivets missing in the front and rear. I'll try to get better photos though and will check the frame and engine numbers if possible.
Picture of the back of the transfer case will tell if it is the correct one piece transfer case or later split transfer case needed for a H55F five speed. One piece case the cover on the back over the transmission output shaft will be a cone. Split transfer case is almost flat. If flat the H55F transmission will have a separate piece between the back of transmission and transfer case. It a few inches thick. Four speed will have a out a one inch plate on the back. Take enough pictures and someone will probably be able to tell you what it has. H55F has two version of top cover. 40 series is pretty rare. 60/70 series locates the shift cane a few inches further back.
So I went back today and took a lot of photos. The frame number matches the VIN plate. Driver's door jam plate is missing. Engine serial number is 2F 382373. I will post some photos of the transmission and transfer case. Again, gear shift knob indicates 5 speed and I was able to run through all the gears without using the clutch except first and second. VIN plate says 4 speed but I'm thinking it has been swapped.
Checked the oil cap and the o ring is intact so shouldn't be an issue. I got nothing on the PS reservoir dip stick.....should have shined a light in but didn't. The brake fluid reservoir is dry; clutch reservoir looked good. Pulled the dipstick and the level was good and oil looked new. Checked radiator; brownish residue, no visible level but no major rust scale. .
I can only find rust issues in a few areas. The driver's and passenger's floor boards are the worst. There is one rust through spot in the bed and one or two in the passenger fender well. Everything else looks and feels solid.
Suspension looks almost new and there is a tag still on one of the springs. Frame also looks almost new or at least repainted. Very strange; it's like this was a project that only got half completed.
A few of interior.....if you can call it that. Windscreen stays (clamps or whatever you call them) are missing. Looks like they were pulled through. Lots of holes in dash. Would this have had an upper and lower pad or nothing? I couldn't read the odometer very well. Looks crooked as well.
@Living in the Past touched on most of this but i will add to his comments with some additional input ,
- Toyota's in the late 70's / early 1980's in the Saudi Spec. region destination market did NOT have Drivers side Door Jamb
Data ID Plates installed at PLANT A11 prior to conclusion of there production on the Assembly line
- a Base Modle or Government issue use Modle would not have had a dash pad , this is normal
- also , I noticed this while examining your photos ? i have NoT seen this before , so i can't speculate how it occurred ?
- i assume thats the e-brake Cable Snapped off at the parking brake drum , ( Maybe ....... ) :confused:
Still a very cool cruiser. I wouldn't mind owning it. Can tell it was always a non heater model with the vent in the center of the cowl.
So I suppose it would be somewhat difficult to add a front heater or is it just a matter of bolting on the right parts? More worried about keeping the windshield from fogging up than anything.
Good catch @RAGINGMATT on the emergency brake. I hadn't even noticed in the photos.
