FJ40 Windshield removal
Asheville, NC
Any of you have any tricks for removing the glass out of the frame besides running a wire around the gasket. My gasket is in great shape and I hate to destroy it but then again I don't want to break the glass.
I cracked mine trying to jimmy it with several screwdrivers,I would ask your local auto glass repair shop.
75 and up?
Pre 75 have a locking seal like a small rubber rope that runs all the way round --pull it out gently and good to go
On the other I would try some some parachute cord soaked in dishwashing liquid and water
and patience, if the rubber is in good shape it should be tough enough not to rip
Don't try to do it when it's cold. Maybe put the windshield down and fill it up with hot soapy water to get everything all toasty, then pick your favorite method.
Bicycle tire levers are cheap and less destructive than screw drivers.
go to your local 99 cent or dollar store and by 2 or 3 teflon spatulas to slide between the metal frame and rubber in one of the corners. use a can of spray white grease (ky Jelly works also, if not embarassed to buy it) spray and run one of the spats all the way around the rubber.. lever the spats in the corner to move the rubber up and out away from the metal. Push on the backside of the glass and and the windshield and rubber will come out in one piece
my gasket was so hard even after removing the locking seal it would not move. Finally trimmed off the gasket around the front of the window and pushed it back out of the frame. BTW, anyone know where I can get gaskets for all my windows. it is a 69 fj40. thanks
hey Dusty66, thanks.
Is windshield glass weather stripping the gasket? Also Which is SOR #3, & #4? I went to post link but did not know what you were referring too.
Well I told my buddy I was going to take the frame and glass to the glass guys and get them to pop it out. Got up Sat. morning and messed with it again. Should have stuck with the original plan. Cracked it all the way across..... Good news is that now I have the frame stripped and the metal all looks good. Now to hit with some primer and start on the fenders.
If the seal is bad, take a razor blade and cut in about 1/2 inch from the window and then cut along the seal about 2 inches. Then pull that part you cut and just pull along and it will peal off that 1/2 inch and allow you to pop out the window. I just did that today. Found some rust in window frame. Going to have a glass guy put it back in for me when I get the new seal.
going in is super easy....getting it out is the hard part.
this is a rear hatch, but the principle is the same.
Thinking about swapping my glass out (pitted and hard to see through while driving into the sun) with the crappy windshield frame with much better condition glass I acquired. Would I need to take the windshield frame off the truck, or could I do it in place??
can be done in place, just needs two people.
one to hold it in place, one to pull the string.
get an oem gasket
I broke mine a couple of months ago because I hadn’t realized that the other side of the gasket had been glued in place with sealant and wouldn’t budge so it cracked.
