- Joined
- Aug 27, 2006
- Threads
- 3
- Messages
- 9
um...is haynes lying to me? the area in the manual for the 4 speed 'cruiser transmission says to "pull out the input shaft" i built a tool to hold the input shaft so i could use a slide hammer. the bearing and shaft pulls out about 1/2" than stops. i also built a tool that locks onto the groove on the bearing than allows me to push on the case with bolts threaded into the tool. i managed to get the bearing almost clear of the case but thats it. i thought that the input shaft was attached to the bearing, a gear and a couple of other goodies that would come out as one unit but is it attached to the output shaft or something with a pin or clip that i'm missing? am i supposed to line up some special domadahikie or what? should i bang my head on the 'box?
