FJ40 Synth vs. tradition oil
After reading a sample from an oil change search I see a preference for the do it yourself approach for too many reasons to reiterate. That said, for those of you who use the Syth. oil can you really see any improvement as opposed to changing the oil more frequently with the general stuff? My line of logic is the cheaper stuff would be better just because you are changing the oil more frequently, thus keeping a closer eye on what is going on with the engine.
Welcoming 2 cents worth on a $100 question.
Welcome.
Keep searching, of everything that has been beat to death out here, this topic has to be right at the top....
You will find enough info to keep you busy for weeks.
Run what you want to.
Good luck!
-Steve
If Poser had his way, we wouldn't discuss anything because it has all been discussed before.
I bought a new 2500 Suburban and I have run Mobile One since the first change.
I change oil and filter at 5K and filter only at 2500 miles. I don't see much change in performance/mileage or the color of the oil. I'm going to stay with it, but will be trading soon and don't know if I would do it again.
Now I have a 2F that I'm rebuilding right now and I will probably run Dino in it, because it will get changed due to time more than mileage.
Thanks,
Thanks for the confirmation. I have a 2F as well and I am going to be running it pretty hard. Giving up the BMW for grad school but not the FJ40. If I have to be poor I will need to look the part too.
H2R
In a 2F there is no advantage to running synthetic oil. Unless you count paying more money fo rthe oil as an advantage.
Run dino. It's cheaper.
Change the oil filter every 2000 miles and the oil every 5000 miles and you should be fine.
FWIW, I run 20w50 in my 2F, run 6000 miles between oil changes, but I do change the filter every 2000 miles.
It's worked well for me for the last 5 years.
