Fe3
Supporting Vendor
The stub we provide for make-your-own exhaust positions the O2 bung right at two inches:
Sounds like a leakOn the old style 6/1 JTO, I used to put them before the gasket on the header. I used to often eat O2 sensors. Since I started moving them downstream it's almost stopped completely.
Dunno. I've learned a lot after doing about 40 Snipers. O2s used to haunt me. Now it rarely comes up.Sounds like a leak
Drum brakes next?Dunno. I've learned a lot after doing about 40 Snipers. O2s used to haunt me. Now it rarely comes up.
How far back are you putting them now?On the old style 6/1 JTO, I used to put them before the gasket on the header. I used to often eat O2 sensors. Since I started moving them downstream it's almost stopped completely.
It's hard to say, I dont have a data point of how hot they were prior to the coating as I was running a stock manifold. I can hit it with a temperature gun and see what they run at temp.How do you like the white lighting coating? Mine just got back from Swain Tech but it will be another month or two before the engine rebuild is done. Does it do a good job of keeping the heat down in the engine compartment?
About where it's illustrated above. 3" or so past the gasket.How far back are you putting them now?
That is fantastic, we are glad to hear that it is all working well for you!I've got about 5000 miles on my DEI heat wrapped Trimeki header and custom exhaust setup (Wrapped all the way to about an 1" or 2" shy of the coupler) and I'm using the Trimeki supplied O2 bung, no issues with Sniper tuning or O2 Sensors going bad. I'm also running a high flow CAT behind the O2 Sensor as well.
