FJ40 LED Tail Light Replacements
Spokane WA
it's just as easy to replace the bulbs in oem housings with led bulbs.
I have a similar taillight assembly I sourced out of Austraillia via eBay. They are much brighter than just updating the bulbs to LED.
Several other members run the same light with positive feedback.
Those resistors will keep you turn signal happy.
Slightly larger than the OEM.
Daylight hours but still bright and a worthwhile safety upgrade IMO.
Good to know! I may give these a try and report back. I like that they are the stock size but I will have to check and see if they come with resistors. Thanks for the info!
I used @SandiaFJ40's LED light kit for my build. They work great, fit into the OEM housing, and run off the OEM wiring.
I finally pulled the trigger on these after an I offered an ebay seller $50 for the pair. I will update on the install. I was hoping to incorporate them into a bumper build that that I coming up.
