Did you have the entire front end apart? There are several threads on this topic on suggestions to get things lined up. I had a hell of a time with mine after having it all a part. But I didn't have any original body mount points that didn't get modified.
If you didn't have your entire front end off but just the hood to do some engine work it's just a matter of loosening the hinges and shifting it around.
If you had the fender and bib and body off you might have to shimmy the body left or right. Running boards on are a good refrence point to being correct. Then if you used a new body mount kit you want to make sure your front bib has a pad under it. Then you have to get your frnot fenders aligned with the proper gap.
I did the fenders with proper gap first. Got the hood to set nicely on the aprons. Then folded up the bib and slowly bolted things together. I took measurements on everything throughout the process as everything moves.
This was the biggest time suck of my entire project and I still didn't get it 100% but I think only I can tell it isn't perfect.
If you didn't jack with your body mounts you should be able to square it up pretty easy.
