FJ40 Hand Throttle Question
Clear Lake, TX
Was the hand throttle pull lever a factory option on the FJ40 or was it standard equipment? What year did the lever location go from the dash to under the dash? I'm still learning about my '79, so I'm not sure if it even has the pull lever. It's not at the house right now, so I can't just go look at it. I was wheeling around in East TX a couple weeks ago and shifting on the hills was a PITA. If I knew I had a hand throttle, I would have used it, but I didn't know where to look for the lever at the time.
all early cruisers(not sure up to when, prolly 67) had a hand throttle as stock, mounted on the dash. then it moved to under the dash......then in the mid-late 70's it went away(maybe in 77-8, last year of the PTO option in NA) 79+ will not have optional or stock in the US. I beleive the non US late models had the cable for the HT moved from the carb to the gas pedal(like a fj60-80)
My 82 fj40 is setup with a fj60 carb(which has the AC idle up) as my 40 has no AC, I use the AC idle up as an electric HT, added the VSV, switch on dash, just pull to bump up RPM's(to where set on carb)
The hand throttle was used with the early 1bbl carbs as well as the PTO. On these, the hand choke was not linked to the throttle, so you needed a way to adjust both for cold starts. I use mine every morning for that purpose.
It is my understanding that while the hand throttle was hooked to the 1 barrel carbs, it was in-dash mounted. With the later carbs that didn't need it, the hand throttle went under-dash and was pedal linked, optional with the optional winch.
Poser said:
My SEP 68 40 had the throttle control on the dash when I purchased it...
It must have come with a 1bbl, right? I don't think any of the 2 barrels had a way to connect a hand throttle. That's why the pedal setup and that's why the knob went under the dash.
I got an extra pedal with the attachment provision for the hand throttle if you need it.
Pedal
I might take you up on that. There are some kits out there with a bicycle shifter lever that will serve the purpose, but the factory lever installed will look nicer. I'll be looking at the LC next week, so I'll let you know.
