FJ40 Gas Pedal
Virginia
Is this a stock gas pedal for a 1977 FJ40?
It was previously connect via cable to a Weber carb. Will it work with mechanical linkage and stock carb?
Thanks!
Jeff
can anyone ID this gas pedal? - Pirate4x4.Com : 4x4 and Off-Road Forum
Scroll to post #17
I think it will work with a mechanical linkage but you will need all the parts. I did the same thing and converted mine back to stock, but mine was the early linkage rod style. I found someone that sold me all the parts I was missing. Yours looks like a late rod style.
No problem. Glad it helps. At first it didn't look like it was from a 77 because it was different than mine, so I did some searching and learned something myself. Do a search or check a parts diagram to make sure you know what all the parts look like.
