FJ40 Door Regulator Replacement
Cartersville, GA
I've been trying to tune up my driver side door regulator. Works fine from outside, but doesn't want to open easily when opening from the inside. Replaced the plastic tabs, adjusted catch, but no luck.
So I have a new regulator, but hoping I don't have to take out the window track inside the door to get this done. I could use any tips or techniques on this. Thanks!
Not sure what you are referencing, but the window regulator can be replaced without removing the door glass runs. If it is the door lock you are referencing, then yes you will have to remove the lower door glass run.
inside door latch
irrc it can be done without messing with window runs, but really it's just easier to get them out of the way and deal with the latches.
they have little plastic keepers on them for the linkage, that are easily broken.
Just a thought... You might find that the felt in the runs needs replacing, and would definitely be a good thing to do while you're in there. It could also help with keeping the glass aligned, etc.
It was the door lock regulator and turned out much easier than I thought. Just remove the bolt on the lower part of the door and the channel comes right out. Good chance to lubricate the window regulator while I was in there.
