Wanted FJ40, '78, VA- Spare Tire Carrier; OEM coolant overflow/washer tank mount bracket; OEM Carb/air cleaner assy; hood; bezel
virginia
Wanted are the following to fit a '78 US Federal-spec FJ40:
FOUND 1. OEM Spare tire carrier, tube type, with hardware. Would also consider aftermarket that mounts to driver's side.
PENDING
2. OEM mount bracket (with or without hardware) for coolant overflow/washer fluid tank. Also need cap and straw w/ hoses
PENDING 3. OEM carb with air cleaner assembly
4. Hood. Color does not matter. Does not need hardware, but cannot have rust perforation or heavy pitting
PENDING 5. Headlight bezel. Same as above.
Located in Northern VA. Thanks
I might be able to help with the carb and air cleaner. Cosmetically, are you looking for functional, or more towards restoration/show quality?
Functional, please. Primarily concerned about heavy corrosion and rust perforation or pitting. Thanks
I"ve got 1 from a 77 I no longer need. Solid but does have some pitting. Would be nice refinished. Includes hardware for mounting and latch. See parts zip tied to the main assembly.
$200 plus shipping. I am outside Columbus Ohio
I messed up and thought I was replying here and accidentally replied to my own old thread. I still have a 78 hood in Virginia Beach but the rust may be more than your wanting to take on.
That’s a bit worse than what I have now, which only started breaking through once I wire wheeled it. Thanks for the response though.
Grew up in Lancaster, so no stranger to rust, but even that is a bit crustier than I’m looking for. Thanks!
Guy has this one in Winchester.
I walked past this ‘78 carburetor on the shop floor a few hours ago. Slated to make it into the cue for rebuilding in about four weeks.
PENDING
- i have your : " Also need cap and straw w/ hoses "
Just found this in my photo gallery last night; think I still have it:
Your store looks like a fantastic resource; I wish I would have found it sooner as unfortunately I ordered many of these parts from international sellers in the mean time.
Will circle back once I take stock this weekend as I think I will have the "need it now" stuff by end of this week, but will look to fully rebuild the heater, washer, and coolant systems over the winter.
