FJ40 350 conversion headers?
Fort Lauderdale
I have a SB 350 in a 68 with power steering. I bought the summit block hugger headers to replace the ram horn manifolds. The passenger side fits well the drive side is too tight to the steering shaft. I have about 3-1/2" from block to shaft at the closest point. The headers are 4-1/2". Can someone recommend a solution or different headers that will fit.
I’ve been running ram horns for 22 years and they never leak, and unless you’re drag racing you’ll not see performance gains from headers... I’d keep them.
In other threads I’ve seen reference to ultra block huggers.
Rams horns are about as low profile as you can get and flow surprisingly well. That’s what I run on my 350.
Look in summit for the Patriot block hugger headers. I run the coated ceramics on my 350 conversion Really cools things down
Nice. Could you give a few details on what it cools down? Did you change over from other headers? Cooler floorboards, engine temp, etc?
Thanks
When I installed the 350 in my Cruiser years ago I was on a tight budget so used the stock 75 Belair headers and ran them for about a year until I finally got some huggers.
Ran those for 20 years.
had to put in new gaskets a couple of time and snug them down every few months.
I welded up cracks until they got to rusty to repair any more so got some rams.
Liked them sort of but had a hard time getting the oil stick in a good position and they were close to the steering.
Bought another set of block huggers, stainless this time.
The cast iron is more maintenance free but I just like the look and sound of the shorty headers with the glass packs.
IMO the only way to go is headers made for the conversion, over the frame rails. I had my exhaust done with hugger type headers originally when I first installed my first SBC. There is no way to route the exhaust cleanly and then you have the mufflers to place somewhere. With the over frame headers you can hang your mufflers under the running boards where they are out of the way and don’t fume out from the back of your rig on the trail. I cut out my running board supports and had half pipe welded in so the pipes do not hang below the frame. The exhaust looks and sounds the best done this way and exhaust components are out of the way. The setup ends up being very short too.
I ran fenderwell headers for 20yrs. They were as tight to the frame as I thought I could get them. At 1st they were great, looked good and sounded great, but as the trails got more challenging the pipes and mufflers would interfere with the rocks and obstacles on the trail. The contact pressure of the obstacle would tweak the pipes & mufflers and create a header gasket leak at the head or collector. One time it actually bent & cracked the header slightly. So, to get the pipes and muffler even closer to the frame and body I cut holes into the front body mount supports and ran the pipes thru it(pic). This was better, but in the end the exhaust would still get hit. It seemed the headers, even in normal driving, were constantly loosening up or blowing header gaskets. Now I run ramshorns, walker Y pipe and the exhaust is well above the frame and clear of any obstacle.
With ram horns and the Y pipe so many people use, why could it not be routed in the stock location?
I've lived through all of the different scenario's above. Routing exhaust inside the frame was a challenge, especially around the slave cylinder area. Over-the-frame Headers (like shown above) let you run a simple and inexpensive exhaust system, but your exhaust is always vulnerable to rock damage. 4 wheelers had no big problems with rocks in the early days, before rock crawling became the rage/the norm. We use to steer around the rocks. Now days 4 wheeling is rock crawling. If you do choose Headers and route the exhaust inside the frame, use Sanderson "Ultra" block huggers, they only stick out from the engine about 3"
LOL! Reminds me of this old Triumph TR6 commercial, from the earliest impact bumper days.
It can be run very similar to how earlier stk 40's are with a stk motor, which is how mine is currently run. Muffler and pipe diameter choices will change the routing slightly.
There are two types out there that I know that are huggers and ceramic coated: Both are from Summit racing:
Patriot Tight Tuck Headers H8052-1 and Patriot Tight Tuck Headers H8027-1 The first are rams horn type, but ceramic coated
The second is the kind I run: Block hugger, ceramic coated
First, understand I went coated to lower engine bay temps, and coated ceramics do just that. On my 71 440 Cuda and 67 Vette it is incredible the amount of underhood heat that is reduced. If you are running a 350 conversion, you know that there isn't a one shot solution to hot running 350's in a FJ. Coated ceramic headers is a great way to reduce temps.
Ramhorns do their job. But if they are raw iron headers, they throw out allot of heat
My headers are great: Plumbing exhaust pipes is a non issue, very simple
Be aware, any header you use can make removal/installation of spark plugs a PIA. Also, burning up spark plug wire boots can be a prob. Most spark plug boots an headers actually touch the headers themselves, causing arcing. I use ACCELL ceramic boots, and they eliminate that problem completey
Thanks for all the info Melvinjo, including part numbers!
I'm thinking about the future for my exhaust system. I currently have pretty decent ceramic coated fenderwell headers and they look and sound great. They don't loosen up and they don't burn my plug wires either.
What I mostly don't like about them is the amount of heat they throw off, and they're right up next to the floorboards so I get a lot of heat radiated into the cab. I've done a lot of exhaust wrap and floor insulation which has helped a whole lot, but there is still much heat produced by these headers. Otherwise I like the setup.
And that's why I ask about your engine bay temps. Mine are coated but I think because there is just so much surface area with the 4 long separate tubes, they just radiate a lot of heat. Was thinking manifolds or shorty headers, spaced away from the floor might help a lot.
Those Sanderson QP1000s sure might fit the bill too. ...just weighing out all the options.
img_0146-jpg.884973
Like the ad. Had a guy make the comment that my cruiser looked pretty good for as old as it is so he guessed I didn't take it off road very much.
I said I try to go around really large obstetrical's if possible.
I didn't mention the time I laid on it's side at Pismo or the big log that smashed the door or the fender that I had to replace after a particularly bad ice storm.
It helps to be fairly good at body work.
As for the hugger headers the only thing I can find any fault with is the collector on mine is closer to the starter that I like.
The header has to be loosened and moved forward a bit to get the starter out and in.
It is wise to also remove the plugs when moving the header.
I drove many thousands of miles with out a shield on the first set of huggers with no problem but a heat shield between the starter and collector wouldn't hurt.
I will get around to putting one on mine one of these days.
