FJ40 2F running too cold?
Hi all and happy new year!!
My temp gauge on the '82 FJ40 never climbs above 1/5 of the gauge.
When i short the sensor wire to ground, the gauge shows full so it seems to work ok.
My convern is that the motor is never reaching the correct temperature but I haven't proven that yet.
The temp sensor I have has 2H stamped on its side.
Maybe it's the wrong one but I looked a t another one at Toyota and it is exactly the same.
Does anyone know what the sensor resistance should be at a known /correct temperature?
What else could be wrong here? The manuals only ever deal with overheating....
Thermostat?
Kind regards
Bernt
is it running cold or not?
if it has heated up properly, you should not be able to hold onto the rubber heater hose for more than about 1 second.
have you checked the thermostat? if the heater hose is warm, and the radiator is warm its probably the thermostat, or someone left out the rubber O ring...
The O-ring gasket gets left out way too often on these engines. It is a separate gasket inside the t-stat housing, not the one that seals around the flange of the housing. Or the t-stat could be installed upside down in there.
If left this way, and if it's hot enough in the summer, there will likely be some summer overheating to go with the winter under-heating.
is the heater hot or not,
mine warms up to about the same point, maybe the third dot, but the heater is nice and hot so I have never concerned myself too much, I think that the PO disabled the fan clutch, which might or might not have anything to do with it.
Mine rarely gets up to what I would expect it to, but the heater makes hot air so I know that the t-stat is working. In winter the guage usually sits at about #2 on the above guage and sometimes on real hot days in the summer the guage gets up to almost half. I used to worry about it but now I think it is normal to most 40 series.
I always thought my F and a half just ran cool, recently replaced the thermostat with a new one (there was a gasket on the old one) and my F now warms up MUCH faster and runs dead center on the temp guage.
Unless you know the history of the thermostat, I would consider changing it.
Check for corrosion etc at the temp sender connection. Too much resistance will prevent the guage from reading correctly.
Hi again,
thanks for all the great responses!
I have done some tests.
The results are mightly confusing to say the least.
I put a lab thermometer into the radiator filler cap after I had driven some 45km (30Miles?). The temperature there was 71 degree celsius.
The thermometer didn't fit in properly because the filler is at a 90 degree angle to the radiator.
I then removed the thermostat and tested it in a pot of water on the stove.
Result is that it opens slightly at about 90 degrees celsius. It opens nowhere near 10mm or whatever the book says. It opens about 1/16 of an inch and closes the slots in the sides by about 1/3rd or so.
I also thought it should open at around 80 degrees rather than 90?
There was/is a rubber gasket in the housing lid but no additional O-ring anywhere. I also cannot see a space for an O-ring. The lower housing half a a recess for just the thermostat outer rim.
It all looked correctly assembled so where is the O-ring supposed to go?
I am completely stumped now!
The engine seems to be running about 10 degrees too cold but the thermostat is not opening properly and at too high a tempoerature.
How on earth can that be? Or am I missing something?
The top hose is warm so water must be flowing through somehow.
What gremlin am I dealing with here?
Kind regards
Bernt
No gremlins. Did you read the article posted above?
Not all have an o-ring but all have a gasket both at the housing flange and at the top of the thermostat - two gaskets.
Your thermostat is opening, in fact it's opening too soon. Remember that a closed thermostat that never opened would overheat your engine by closing the flow of coolant.
Buy a new thermostat. Be sure to install both gaskets or the gasket and the o-ring. Depending on year it is spec'd to open between 165 degrees fahrenheit and 190 degrees same scale. These numbers are generics that I just made up, or ballpark figures. Don't fret too much over measuring the distance or size of openings in thermostats. They either open or they don't.
Spector actually sells a thermostat that opens at 190 F for cold weather applications.
Sorry for jumping in here...I just bought a new thermostat. Parts store told me they had a 180 degree one (OEM spec) and a 190 degree one. I went with the 180 (don't really know why). When replacing the t-stat, is there a torque setting for the housing bolts?
