1980 FJ40, 2F engine - Not sure if I am starting to lose my head gasket so I thought I would ask the experts for some advice on how to determine if its going bad.
Some background info: Had oil leaking down the side of the engine on the manifold side so I put UV dye into the crankcase to determine if it was just valve cover gasket, or if the the head gasket was also leaking. Turns out that it was just valve cover gasket. While replacing it appeared like there was coolant around the valve train, but wasn't 100% sure because it could have been the UV-dye.
So this got me tuned into a possible head gasket going bad. Coolant level has dropped slowly in the past, but with factory air and being in Texas I chalked most of that up to the coolant boiling off when the car was stopped...if I had the air on and ambient temp in Texas was 90F plus and then turned the car off for 5-10min when I restarted temp gauge was VERY high.
Anyway, looking through old threads I found one suggestion to loosen oil drain plug a bit as coolant will settle to bottom of pan and drain first. Any other suggestions? Was thinking of using the UV dye in the coolant to check for coolant in the oil.
Also, if it is a leaking headgasket how bad is it for me to drive the vehicle? Any risks to engine?
Finally, if I do have to replace gasket, is there a lazy man's way of doing it? With all the smog equip I have on this rig I would love to just disconnect the exhaust near the downpipe and pull the head with the carb, manifolds, smog stuff all attached. Any chance of this?
Thanks
Chad
Thanks
Chad
