Hahahha.that looks like you let the smoke out of it.
Yep igniter 2 fixed it. I had issues with Pertonix in my boat my igniter III remember something about pertronix modules burning up if the key was in the on position for a period of time. I also believe ignitor 2 fixed this.
How Do I Test a PerTronix Ignition?
Upgrading older points-style ignition systems to modern electronic units is a popular upgrade. Replacing the antiquated mechanical points with accurate and dependable electronic components increases the engine's performance and fuel economy. PerTronix is one brand that manufactures aftermarket...itstillruns.com
Thank you!I will never install another Pertronix module in any car I own. I had two fail... one of them was less than a month old. They are way overpriced for what they do, so now I just build my own HEI systems using $20 GM style modules and the plans available on the internet. The Flamethrower coils are completely unnecessary once you make a good HEI system and make sure that your wiring is upgraded from the battery and ignition to the module using a Bosch style $5 relay. Look up "HEI ignition using points to trigger". The points are only used to trigger the module and carry virtually no current, so they last forever. The only wear is on the points rubbing block, so occasionally (every 20,000 miles or so) you might have to adjust the point gap. A standard OEM coil will shoot a 1" spark once you assemble the HEI module with the upgraded wiring. With the GM style module, even if it fails you can get another one at any auto parts store for $20, try that with a Pertronix that has to be matched to your specific dizzy.
