I can't tell from the photos but I see a vacuum line going across the valve cover to the throttle body, and I'm guessing that is hooked up to the distributor. Have you tested the vacuum diaphragm in the distributor?
Please some pics would be helpful to my eyes so I’ll check ur sigUnplug the hose from the carb and plug that port, then see how it runs. Also, don't use that manifold gasket, they are terrible. Get a remflex gasket and save yourself the headache
Side note: I just re-installed all of the factory smog equipment back onto my 78. Check the link in my sig if you need to see any pics for reference.
Is your idle circuit cutoff solenoid connected? Is it energized? Is it funcioning?
Aside for everything else said in this thread, I see no mention of the solenoid at all. Maybe I just overlooked it as I scanned. From the symptoms you mention, that is the very first thing to check.
Mark...
Just run a jump wire to the coil to test it. That’s what I did for @airon23 when I was passing through Reno a few years ago.All the sudden I don’t hear the click - checked my connections look clean as I did them, will get my tester and test is any volts going to from my 7th circuit breaker? Maybe I out in a 10 when it’s supposed to be a 20, BUT no blown fuse’s at fuse bank …
I see hmm maybe bec of the trial headers there’s something in the way and I need to ground it some other wayIf that’s a single wire solenoid, the carb body to intake manifold to block… is the ground.
Remember guys my car might be a Canadian import as my Aisen Carb is non-USA model which Jim C seemed to be very happy about for whatever reason. and im still sending it to him regardles of these vac isues that ill fix while its gone being perfected by jim c
wheres @ToyotaMatt when I need him to over-explain everything perfectly so i feel like a profesh after speaking with....lol
When I removed the emissions from my 78 I replaced the carb with a Rochester 2 jet and it had a mount for different jets. When I was in college I blew the head gasket and pulled the head for a valve job. I asked the shop to mill the head and I didn't know how much and trusted them to take the right amount off.ok so my 40 has been running rich since i bought it. P.O. ripped out emissions system. im in CA and I just got a stickerdont ask how...lol...anyways the main story i need help with is getting it to run without me having to turn the fast ide up basically all the way AS WELL AS having the choke out halfway just to keep the damn thing running at stops when i rpm down.
super annoying. Guy says just get a new carb. So im like okayy i could do that and im happy to do that but because P.O. ripped out emissions system, if I ordered a new '76 carb I'm nervous that I'd have to adjust it to work with my rig - meaning if no emissions systemprese t then all the vacuum lines that go to the carb are non-existent. therefore i just cap them?
i have no idea how my P.O. (or his mechanic) manipulated the carb to work. after studying it (the carb) its a combo of two different years - top part / bottom part - 2 different years (if im correct - i looked on the carb identifier on SOR so im pretty sure im correct).
I also know tons of people rip out their emissions systems so there should be some easy way to deal with a new carb.
i bought a rebuild kit for a '76 carb - took the ****er apart, cleaned the jets added the new seals and whatnot - put it back together - same ****ing problem. so im exhausted by this, I just wanna be able to drive my 40 without tasting gasoline in the nostrils. lol
anyways im thinking smaller jets i dunno, im lost on this and no one around me will help me. ive tried valley hybrids, mudrak. they are the only ones close to me, but i cant get them to even look at it. super annoying. their always "busy" and i cant "get in line" bec their 'workload is too high" ... I just need an assessment and ill do the work myself s***.
do you guys think i should just a new carb or what?
thank you for any assistance or suggestions based on what i said.
Ok no click see pics of how I attached and did…,
did you bench test this 1 wire version above yet kyle ?
- ground the gold zinc housing
- B+ the wire plug end
- i should click YES !
- if not ?
- it is bad and you need a new one
- the below is my 2 wire later modle version Kyle
- it WILL and does plug and play on ALL 1/75-9/87 2F carbs
- the extra 2nd wire is a polarized ground
- this ensures it CLICKS all the time reliable and safe too
but first , confirm and verify your current one , also KEY ON and and test light the black wire w/ yellow tracer stripe that plugs into it now ,
