Build FJ 45 Extended Cab Custom Vehicle Build Finally Begins
Make sure your filter is full of diesel and that you can hear the fuel solenoid click when 12v is to it. this will save you alot of trouble. I cracked all four lines on mine and turned the motor over until one spewed out, then closed that one off, and cont..
Things im sure you know, but Goodluck! cant wait!
My To Do list is getting shorter.
Yes that is a 3' x 5' dry erase board. :D
The ram I need for this rig is 7 1/8" stroke. PSC installed the 7/8" spacer block in an 8" ram ram. No Charge. Yep, 1.75"
I thought I need to move on a 8" ram next time .. ( next life :D )
Are you plan to move it with the stock PS pump ?
Stock as in a Cummins mounting style one hi flow output one designed for a 30' cargo van? Yes.
I checked with the guys at PSC and they said to try it first and if I need it rebiuld to send it to them and they wil modify it and rebuild it.
They did recommend going with one of thier rebuilt/modified ones if I was going full Hydro.
The new 2F pump I used on the previous 2F had no problems.
Hijack .. before buy the " wrangler " pump that I got .. I got the Cummins recomendation .. the only issue with it was the 260 buck that it cost and need to make a pulley .. for my setup ..
Now I'm not sure what's happend in my case .. so not sure If I need to buy a new pump or what ..
I mail back to Kelvin at PSC with no more answer .. :frown:
hijack end ..
:popcorn::popcorn:
Second Problem Found
Brand New Optima Yellow Top putting out 6.6 volts. Connect the Pulse Charger and found the battery is bad.
I hate optimas..
Garbage..
My blue top has treated me well. Everyone who has problems with them does not DD their rig, from what I've observed :meh:
time ago I bought 2 yellow top .. one last less than 6 month .. other still doing the job ..
How bout the 2 yellow tops that just died in my camper (less than a year old) that was plugged into a charger the entire time??
optimas are a crap shoot with quality now a days. DD or not, they should actualy be able to last.
i dont like optima batterys either I am an Odyssey fan
Bravo for working with your OEM harness. Once I got into my harness I realized it wasnt worth dealing with and pulled it out and installed a aftermarket one.
Good luck getting it cranked over
