Build FJ 45 Extended Cab Custom Vehicle Build Finally Begins
Getting real close.
The Cummins 4BTA/NV4500/Orion4:1HD is assembled.
I installed a new flywheel and a new Luk Clutch assy and a new throw out arm assy.
I tightened the bolts down in 5ft lb increments and snapped 4 of them off when i hit 20ft lbs. I guess I just figured Grade 8 5/16" clutch bolts should be tighter than that.
Nope 17ft lbs is the spec.
I found out that my engine hoist does not want to pick up the assy over 18" from the ground. :mad:
After hefting the LV onto the trailer, that engine, tranny, t-case combo should no problem for the tractor. Then again, after seeing you lumber jack those big hunks of wood around on your shoulders I am surprised you are using any type of lifting device. :grinpimp:
I cheated and copied this out of my thread but it's good for reference. Hope to see your rig at Rubithon!
This is the KDP, the killer dowel pin. It's located to the left of that bolt head. This thing will work out and you can see what kind of damage it could do with all those gears working together. The pic makes it look like it's close to level with the case but my pin is actually seated well inside the hole which was a good sign.
The fix is very simple. Restrict it from coming out. I had an broken scale laying around that I cut a piece from. I shaped it, bent it, removed all the paint from it, and fastened it with the bolt that was already there. Now if the pin tries to come out it will hit that tab and it will stop it. This is a common problem on the 4bt's and the 6bt's. One of the very few problems needing to be fixed on these engines
I worked on the engine mounting brackets today. I did not want to use the stock front mounts because this assy is so long between attachments points. It would be bolted down on the front of the engine and the AA adaptor behind the NV4500. That leaves about 4 1/2 foot between attachement points with a few things coupling it all together. I read on a different site that the bell housing will crack if supported this way.
I moved my front mounts as close to center of the engine as possible. The rear mount will just "balance" the engine.
It takes awhile when fabing with 3/8" plate steel.
I decided to use the Cradle design instead of the flat design. I am using new 2F engine mounts. if I used the Gell mounts, I would have had to mount them flat.
Here is the exhaust side.
