@landtank 2 questions; 1) In the fender meaning if you removed the outer fender for say trimming you would see this relay? 2) Is this a common failure point? If not how was it isolated to this relay?
It mounts to the inner fender near the ABS actuatorv
And ye of much skepticism shall bow to the ample experience and intuition of @landtank, and trust in his divine knowledge of the 80 series, so Sayeth landcruisinmy93Ive had problems with that relay before. And Scott mentioned a few tines it seemed to be more prevalent pulling up a hill.
My first check based on the hill comment is to do a brake stand and see if that creates the problem. It didnt so on to the next possibility which is the FPR.
Its during those times that FPR will switch over to the high side to drice the pump at full voltage.
So diagnosing this was some intuition and a little experience
What led me to start following this thread was the melted fuse. I had a slightly melted efi fuse occurrence on sunday. I have followed the burnishing step of the relay but I have other problems elsewhere. I have 14 amps across the efi fuse. It is hot to the touch after several minutes of idling along with the efi relay. I will have to start looking at all connections and searching for a high impedance to ground on the respective circuits. It has to happen on the efi fuse....can you say searching for a needle in cruiser. Oh well I will try to make a list via the EWD and picking away I guess. I probably will just start a new thread. I already boogered this one up.
