So the 80 took its first ride on a tow truck.
I left for a friends party in the afternoon and I noticed on a uphill it cut out 2 times for a second.
I hadn't drivin it in awhile so I filled it up with 93 octane and didn't think much of it.
When I left my friends house the 80 made it about a 1/4 mile and coughed a few times then just died.
It turns over very strong still but no sounds from the fuel pump. I switched EFI relay's but that didn't help
I noticed a melted 15amp EFI fuse right in the same box. I pulled it. cleaned terminal and popped in a new fuse. Still nothing. No fuel pump sound. I might have to re wire the efi fuse to another spot on that panel as it did a little melting.
So I called triple A. I will be looking at it tomorrow.
Just looking for some suggestions.
One suggestion I got from a friend was that a few 80's out there have had harness shorts inside the tank for the fuel pump itself. I will be pulling that out first to check.
Mine did the same thing. I replaced the EFI wiring and it's worked for the past two weeks just fine.
