First post... Fan into radiator
One other thought. This situation has come up with supercharged applications running the Wits End/Landtank orange clutch. While I know it is kind of apples to oranges, the problem arose with the orange clutch that the fan could hit the shroud (with heavy acceleration) right at the bottom drivers side of the shroud. I know this to be true all to well. The current shroud from toyota has this area clearanced out which solves the problem. Earlier shrouds have to me modded for clearance. My thought is that perhaps a bad clutch or engine mounts might be enough to hit the original shroud on your 80 but maybe still clear on the new shroud. SO if you do buy a new shroud and fan, you may be good to go already.
The engine mounts are fail safe right? The top steel cover drops down onto the lower mount if the rubber fails, is that enough movement to let the fan reach the rad?
Regards
Dave
That’s how it worked on mine. The passenger motor mount had been wasted for some time.
I'm using the scan gauge several others are using as well.
MINI ScanGauge II Mount
In your Mini or?
Regards
Dave
In your Mini or?
Shroud is installed correctly and tight, as is the radiator. I’ve read that blue clutches are supposed to be mated with newer designed shrouds?
Pics coming soon
Pics coming soon
Blue clutches run fine with the original shrouds, even with a SC. Mine hadover 150,000 that way.
In my Cruiser and LX450
So, did your fan make contact when the mounts let go?
And an update for everyone else...
Going with the 65010 fan per about 4hrs of digging through past posts and nerding out on fan dynamics. If this fails, I'm going crown-vic fan.
Starting a build thread soon too.
Have you replaced your engine mounts recently? If so... did you remember to put the dust shields back in?
Dust shields? Can you imagine how much time it would take to detail the dust off of the motor mounts without them?! :hillbilly:
The caps interact with the rubber knobs on the sides of the mounts, limiting mount movement, controlling engine movement and extending mount life. They also work as a somewhat successful fail safe if the mount fails. In other words, a good thing to have?
Ya know as I get older I realize that I know less and less.
I assumed -incorrectly- the caps were an oil/dust shield for the mounts as its common knowledge that most types of rubber degrade when exposed to oil / petroleum products.
What you have explained makes perfect sense as well, however I would bet that the cap like design provides the secondary benefit of protecting the rubber from exposure to oil and other degrading contaminates, which would help prolong the mounts life.
With that said I have seen several engine out rebuilds where the caps were forgotten, if driven without some type of a spacer in its place it can very easily cause the fan to hop the bottom part of the shroud slicing the bottom fins on the radiator..
FWIW, inspect your transmission cross member. Happened to me on the Shortbus. The crossmember had a hard life and was bent up quite a bit, causing the front of the motor to be lower than what was expected. Fan caught the bottom of the shroud and made a nice circle in the radiator.
Noted, and will do. Would 2 days of relatively easy trail really be enough to do that? It’s like it happened completely out of nowhere.
In fact, I’ve had it for over 1400mi (most of it pavement) and randomly my fan decided it was time to eat my radiator...
