I can do OK with the pallet forks on flat ground, but it's near impossible to grab logs going downhill. You just push the log further away from you! Usually I've gotten off the tractor and hand-loaded the forks - or have my wife drive the tractor while I load, which is super labor intensive. Really looking forward to just grabbing and moving them!The grapple is a fabulous tool addition. When I built the pole barn, the bulldozer knocked over about 30 red and white oak. Most about 18” diameter. The grapple on the skid steer moved them all in 4-5 hours only cutting then in half
I brush hogged on a 1952 8N for about 15 years. Great handling little tractor and perfect for mowing. I looked for a used 4x4 Kubota for at least 6 months before we went to build, but used tractor prices are bonkers. So I bought a new JD instead - 2022 that was still sitting on the dealer's lot in 2024 - probably because it had a manual transmission. It's about the same size as a N tractor! Big enough to lift up the 35' steel beam for our house:My tractor is a 1947 Ford… it’s an aerobic exercise getting on and off the seat as the framework for the front loader is blocking everything I can add forks to the 3-point but chose the bolt-on ones for the front bucket. Sometimes I can only load it by hand as the bucket does not articulate and goes up or down and release. Trip bucket…it’s like yelling “timber” in the woods and hoping everyone is out of the way
By the way, these chains came today.. some reviews say they cut VERY aggressively and unless you have professional experience, this chain is not for you… I ve been using a chain saw over 50 years..only had a slight incident on to my left thigh…
The scar is still there but damn, that scares me now that I’m older and weaker![]()
