Adjust valve clearance
Set no 1 cylinder to TDC/compression
Turn crankshaft to align the timing marks at TDC set the grove on the pully at the 0 mark position timing mark.
above is an exert from the FSM when I align the mark to 0 my pistons are not at TDC I am rebuilding this engine the head and timing cover is on..while adjusting the valves it seems the valves are hitting the pistons we are just using a wrench and when it acted up there was no forcing it... the harmonic balancer if off of a different engine crank shaft....
What the heck do I need to line up for this thing to work..
