i could be wrong i am too lazy to go look right now, but i thought the pulleys were bolted with 4 bolts to the center of the balancer.
my manual does not say to adjust the valves hot and i adjusted them the way it said and have not had a problem. and my manual is from Toyota. i also adjusted chris's by my manual and is far as i know he has not had a problem.Sounds to me like you didn't find TDC before you put on the timing chain....
Also, valves are adjusted hot, so don't worry about that yet.
IH8Haynes
ray it is about time to do the 30,000 valve adjustment on mine i will post up if there is a difference.
maybe after 30k everything is seated and worn in place sort of speak. that is why to do it hot at 30k.... and cold at rebuild start up.. I am also using the rv cam from engbldrs.com so the adjustment is different..on a rebuild there is hypothetically no wear. after 30,000 there is. well that is my theory but it is the same even if you are reusing the old parts so who knows. i guess the toyota gurus must have.
adjust them like the book says then run it and get your timing and all other little adjustments right then use your own judgment and re adjust when at operating temp at the 30,000 or 3 month mark. in other words if it is noisy after you get every thing else adjusted re do your lifters if not wait till the first schedule maintenance.on a rebuild how could you adjust the valves hot... run it all noisy and out of any type of adjustment?
and no i used the adjustments in the manual, and now i am coming up on that 3 month mark i will check and see if they need to be adjusted.Like the cold and hot clearances before you adjust?
That sounds like an experiment.![]()
